I need a headcount template report for my business
On a tight budget, I resorted to virtual office. I have employees all over the world. I need a headcount template report for my business. Freeware or Commercial.
Answered By 5 points N/A #132691
Dear user,
A headcount report is no doubt very necessary for a company, as it gives the report which contains information including the company's progress. You have to use the Microsoft Excel if your company's budget is minimum to make this report. Otherwise you can use other softwares. You can read the instructions given on https://bizfluent.com/info-8197078-employee-headcount-report.html. This will be very helpful to you. You can use e-HRM Inc to make your report, here is a sample report of this software:
Hope this will help you.
Thank you.
