Mickhel
70 points
Posted on - 10/10/2011
I am using various kinds of font . I need some fonts to be installed. And also, I do not know how to find Bangla font to use in pc. I am trying many more times to use Bangla font . I have also installed Bangla font Bijoy . But i cannot use it. I do not know why and how I could use it ?
Jesmin
jimmytoy
15 points
I want to use Bangla font Bijoy
 Yes the font Bijoy are mostly in the form of zip format. So after downloading the fonts must be download the software winrar which can enzip the files of zip format. One another is pkzip which can uncompress the files into the ttf format. When you want or you have the choice to use it than you can download and install or can be copy these ttf font files in to the your windows default fonts folder. Like in to the folder C:/windows/fonts directory. You can use the Character map like feature of windows from the accessories. There is the Bijoy Keyboard Layout –
lee hung
75 points
HI Mickhel,
To use bangla font bijoy in your word processor, you first need to download and install it on your computer-it comes in a zipped format. Once you have installed it, you should see an icon at the bottom of your computer screen which is to be used for bangla font.
Now open ms word and press ctr+alt+B key combination, which should cause a red circle in the icon to be changed.
You can now go to ms word menu and choose any type of bangla font that you want to use.
Hope this enlightens you in a way
____
Lee Hung.
