Info On Dell Power Edge 2950 Server In Short.
Hi, I am cogitating to buy the Dell PowerEdge 2950 serverĀ online. I need to know its features before buying. What are its specifications that make it a better device?
Answered By 0 points N/A #299556
The Server has the Rack-mountable chassis with eight number of Hot-Swap bays. It is manufactured by Altigen which can operate at the max temperature of 95 degrees. There are two numbers of Gigabit Ethernet and it runs on Xeon processor. It can house DDR2 SDRAM at the memory speed of 667 MHz. In India the Server costs you more than one lakh rupees. There are three generations of the server, buy the one which suits your need.
Answered By 590495 points N/A #300479
The Dell PowerEdge 2950 Server ships with Intel Xeon processors and can be upgraded up to two processors of the following processor series:
  • Quad-Core Intel Xeon 5300 series – up to 3 GHz
  • Quad-Core Intel Low Volt Xeon L5300 series – at 2 GHz
  • Dual-Core Intel Xeon 5100 series – up to 3 GHz
  • Dual-Core Intel Low Volt Xeon 5148 series – at 2.33 GHz
The Dell PowerEdge 2950 Server may come pre-installed with any of the following operating systems:
  • Windows Server 2003 R2 (Standard or Enterprise) both 32-bit and 64-bit
  • Windows Server 2003 R2 Web edition 32-bit
  • Windows Storage Server 2003 R2 (Workgroup, Standard, or Enterprise)
  • Red Had Linux Enterprise 5 (Advanced Server)
  • Red Hat Linux Enterprise 4 (ES and ES EM64T)
  • SUSE Linux Enterprise Server 9 EM64T, SP3
The Dell PowerEdge 2950 Server has 8 DIMM slots which supports up to 32 GB RAM (256 MB, 512 MB, 1 GB, 2 GB, or 4 GB) Fully Buffered DIMMs (FBD) at 533 MHz or 667 MHz. You can upgrade the internal storage up to 4.5 TB. For the complete details, head down to Dell PowerEdge 2950 Server Product Details.
