Problem with 0X8007005 error code
I have Intel dual core computer. When I start my computer sometime I get a error message.
That shows that I have driver problems in my computer. 0X8007005 this error code shows.
Error Message
Error Message
An error has occurred (code: 0x80070005)
Please update your drivers and run the 0x80070005 repair tool
I get this error code. What should I do now . Please help me.
Best Answer by kate_wilson
Answered By 15 points N/A #94824
Dear Eric Cribb ,
  • Is you using original windows operating system or pirated? If you are using pirated software then you just need to turn off automatic update in control panel and update your device drivers and this error message will not disturb you again.
  • If you are using genuine Microsoft windows then you should do some steps for resolving this issue. Download Microsoft genuine advantage diagnostic tool from Microsoft site. Simply run downloaded file and hit on ‘continue’ button. Hope this will automatically fix your issue and after this a message will appear “validation status: genuine”. Now restart your system.
Hope your problem will be resolved.
Kate
Answered By 0 points N/A #94825
  • The error you have encountered is primarily caused by missing Windows files that is essential to work with your hardware. Hardware needs drivers installation so the driver files might be affected as well because it is also being called by the operating system to make it work.
  • Missing Windows files can be developed by the bad sectors existing in your drive where windows file are placed and affected. You can perform the check disk using the check disk utility to recover damage or lost files. After the check disk is done, it should solve the problem.
  • You can also download Error 0X8007005 repair tool at  http://simple-pc-help.com/How-To-Fix-Error-0x8007005/   to diagnose and fix your problem but it is recommended to run check disk first for better results.
Answered By 5 points N/A #94827
This error can cause your computer to run slow and might even make other programs to not run properly. And worst, it can even cause Blue Screen of Death. Error 0x80070005 is a common error that starts from your Task Scheduler.
If there is something wrong with the Task Scheduler or your username is invalid, it can trigger this error to appear. I suggest to scan your computer including the registry. To try to fix this, you can also try the solutions below:
1. If you are trying to open a folder when this error appears, right click that folder and then click on its properties.
2. And then go to Security tab>Add>Advanced>Find Now.
3. Select Everyone and then click OK.
4. Select Apply and then click OK.
5. Use the same username and password to create new account.
6. Under the Administrator group, add the new account to the group.
7. Login with the account you just created.
Alternatively, remove unused files in your computer. Scan on a daily basis and run a virus scan.
