Supported OS Of Program To Check Cpu Temp Its Software Too
Hell, notify the supported hardware for program to check cpu temp and also mentioned some software’s of it too. Reply soon and thanks as well.
Hello, the program to check cpu temp need the hardware specifications such as the CPU core sensors should be min. of Intel core 2 or more, the main board sensors should be in ITE IT8620E , the GPU sensors must be in Nvidia and the HDD must be SSD wear level only. Below show the top rated software’s for the same as well:
• HW Monitor
• Open hardware monitor
• Open temp
• CPU thermometer.
• Speed fan etc.
If you want a program that allows you to monitor the temperature of your CPU as well as other components in your motherboard like the memory card or the memory module, hard drive, cooling fans, and others, you can try Open Hardware Monitor. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit.
Open Hardware Monitor is a free, open-source application designed to monitor voltages, temperature sensors, load, clock speeds, and fan speeds of a computer. It can track CPU temperature by reading the core temperature sensors built-in to Intel and AMD processors as well as the sensors for NVIDIA and ATI video cards and SMART hard drives. Aside from Microsoft Windows, it can also be installed on 32-bit Linux operating system.
The latest version added the following features:
