Archive
I have a Macbook. When I try to delete files from the Trash or attempt to empty trash, I encounter an 8003 error. How to fix it?
Read moreI am unable to use my PS3. I encounter the 8002a537 error code. I am unable to find any solution. Is there any solution available for the 8002a537 error code on PS3?
Read moreWhen I try to update Windows 10 using the Windows update center, I encounter the 800072ee2 error. I ran the troubleshooter, then restarted the services, renamed the software distribution folder, and turned off the firewall, but could not solve the error. Is there any other way to fix the error?
Read moreI encounter an 80004005 error when I open VirtualBox on my Windows 10 PC. The Virtualization setting is on, and I have all the necessary components. I am using VirtualBox for the first time, and I have no prior experience. Is there any way to solve the issue?
Read moreI have a game stored in the cloud, and when I try to access it using my Xbox 360 console, I encounter an 80004004 error. How do I get rid of this?
Read moreWhen I try to delete temporary files created by a newly installed software, I encounter the 80004002 error code. The error says – “No such interface supported.” In the task manager, the application is not running. How to fix the error?
Read more2 finger scroll not working - Asus, Windows 10 PC. Updating the driver did not work. I think this happened after a Windows update. What to do?
Read more2 out of 3 USB ports not working on my HP laptop. I don’t know how this happened. Please give me a solution to this.
Read moreI encounter 1962: No operating system found. Boot sequence will automatically repeat error when I turn on the PC. I have a Lenovo laptop with Windows 10. Is there any way to solve it at home?
Read moreIs there any way to fix the 1935 error code when installing Office 2016? I have a Windows 10 PC with .NET Framework. I am unable to figure out the issue. Please help.
Read more
