Archive
I want to repair the Norton which is installed in my system, but I cannot remove it from the control panel. What can I do? Please help me!
Read more
I have a serious problem. I want to remove bloodhound w32 from my PC.
It gives me more problem to remove this.
Can someone help me?
Read more
i am trying to cancel an auto ship program involving a product. when i try to contact them at the email address i was given, i get this. "could not perform this operation because the default mail client is not properly installed. what does it mean? what do i do to correct it?
Read more
I keep getting notices that I need JAVA to see certain webpages including my online banking and some games. Where can I get MS JAVA plug-in?
Read more
I keep seeing the same list of windows XP updates appear even after I have downloaded and install of them. Sometimes windows updates just hangs. Is there anything I can try?
Read more
I have one question and I will be very grateful if you help me.
I am hesitating between two video controllers:
ATi HD3650, 1GB PowerColor, AGP8x, DDR2, 128bit, DVI, TV Out
ATi HD4670, 1GB PowerColor, AGP8x, DDR3, 128bit, DVI,
My video slot is AGB x8 on Asus K8V-X SE Motherboard. So my question is can my Motherboard use DDR3 memory?
Read more
when i run disk clean up,  it gets to the first three bars when checking the files(status bar says "compress old files") and then just hang there? if i close it down and run it up again, then it just never comes up at all.
Read more
I have a problem where my taskbar disappeared and there is no start button. This happened after windows explorer opened an unresponsive folder.
I know that this will be corrected if I restart the computer but there is another way to get the task bar without restarting the computer?
At times there are still applications that I am working on and I lost my work when I restart the computer. All the best!
Read more
Please help me how to make my internet connection faster? I am using a plug-in broadband.
regards, karen
Read more
Hi experts,
How to convert a PowerPoint Presentation to PDF file, so that it can be edited in an iPad?
Thank you.
Read more
