Archive
Whenever I try to play a game or do anything with any of the adobe software, after running for 10 minutes or so, the program crashes and says something like "memory location could not be read".
I have tried re-installing windows but the problem remains. So I guess it's a hardware problem. I desperately need help on this please!
Read more
Hi, umm I've been using AVG free edition for a long time now, but I think I'll switch to something else. I have two choices, Kaspersky and panda cloud antivirus. Which one I should go for? Any idea guys?
Read more
I was trying to run a server emulator for some reason. The emulator installed alright but when I try to run it, it says port 80 is already in use. I have tried closing all applications but had no luck so far. Can anyone help please?
Read more
After Windows 7 what is the name of the next OS windows would release and when it would be release?
Read more
Code blocks here I install Windows XP and when I start a project with C, I have 3 error messages that arrive "Does not know how this wizard to setup this warning flags for compiling" then "Does not Know this wizard to setup debug flags for this compiler" then "Does not Know this wizard to setup optimization flags for this compiler" after I make my program and all the codes and when I try to run (build and run) I have a message that appears at the bottom telling me " jon - Debug "uses an invalid compiler. Probably...
Read more
I received a recommendation to install SmoothWall Express 3.0 software firewall for my home network of five PCs. The instructions say that I boot to the CD, and run the installer which will wipe the hard disk before it installs.
What? Wipe the hard drive?
Any software that wants to clear my hard drive should end up in the trash can.
However, I can reinstall most of my software but for a firewall to do that it makes no sense.
Read more
Hey,
We are planning to migrate from Struts to JSF. Can someone suggest a good JSF framework with good UI components?
Read more
I got a cd from a college friend of mine who said it contains his ideas for a profit making website, but it is full of files with the extension .php, how do I open these files on my computer?
Read more
Can you please also tell me that Microsoft is promoting the Microsoft Office Communities within the Office products extensively.  Do you think the Microsoft Office MVPs had a role in the overall development of the Office 2003 System, and do you expect to look for their expertise in future versions?
Read more
Is password protection function also present in Microsoft Office 2003?
Read more
