Archive
I'm using Windows XP for three years now. I noticed that the features in Windows 7 are quite good as compared to XP but I also heard a lot of negative comments about Windows 7 like its not user friendly, spy ware is not good, etc. Can anyone give me a good comparison of the two OS? Thank you.
Read moreHi,
I am a Windows newbie and I just wanted to ask, how to totally personalize my Windows 7 account, like screen savers, colors etc?
Read moreMy computer starts to hang, crash and encounter blue screen (BSOD). Prior to that, my computer was running fine, so I thought it was just an operating systems' (OS) problem. Then, I decided to format my computer. But when I tried to install the OS after formatting, the installation stops and display blue screen.
I already tried different installers and operating systems but I still encountered the same problem.
Read more
Hi Experts,
I have a 17" monitor that's 5 years old and have been facing different issues. Some times there is no display and some times there is a lot of lines which effects me from working.
It display looks like shuttling up and down which happens when there is low power.
I have checked these.
1. Power supply watts is fine
2. Earthing is fine
Thanks in advance for the help
How to insert cells,rows and columns to a table in ms word?
Apple products have always fascinated me. Recently I saw an Apple wireless keyboard. Since, I don't own a Mac, will it be able to connect to my Windows Machine? I can go ahead with my plans of purchasing only after this confirmation.
Read moreI always want to use Chrome in incognito mode. I do not want to open Chrome, and then turn into incognito mode. I want to keep it on, as soon as I launch Chrome. Help!
Read moreI see CPU starvation messages on my Websphere server logs but there has been no impact on our application. Is this something I should be worried about? How can I find the cause for this?
Read moreHi, sometimes when I run my Java code, I get some exceptions but no stacktrace. I have encountered these even in debug mode. Does anyone know what I might be doing wrong?
Read more
Can somebody help? I have a problem where my desktop's display size became too large. I went to display properties and tried to adjust the screen resolution to the right but the slider is greyed out. I also tried restarting my computer but the display size is the same.
