Archive
How do you prefer your style of work with the ideal test administrator? To be more specific, what are your functions at work and what are the dissimilarities of the way we've work and the function you described?
Read moreDoes importing package and sub package in JAVA the same? For instance, when we try to import com.MyTest, is it the same as importing com.MyTest.UnitTests?
Read moreMy OS is Win 7 64 bit.
I got an excel attachment in my Hotmail which needed some editing.
I opened it and edited without forgetting to save continuously but later when I reopened excel, the file was missing.
Did anyone have such an experience?
If so, please help me to fix this problem.
Read moreHow can I send data to traditional Systems Applications and Products (SAP) systems and dual stack SAP system? How could I identify that the legacy data is running on the SAP server? Anyone help?
Read moreYou are working in your project where the qualification changed dynamically. The files in the project come from several ends or multiple platforms and are interdependent. As you can see, this is a great risk with this activity. How could I make proper plan?
Read more
I am a beginner when it comes to Toshiba laptops since I just recently bought one (Satellite L355) 6 months ago. And I have a problem with its battery life which started last week. When I am traveling and running it by battery, it only lasts for a couple of minutes, 17 minutes is the most. I tried lowering the brightness of the display but still, the same result. I want to buy an extra battery for it, but I am a bit hesitant since the battery has only been used for 6 months considering that I...
Hi, I launched Adobe Bridge but then I got this error message (see below).
Adobe Bridge
Bridge encountered a problem and is unable to read the cache. Please try purging the central cache in Cache Preferences to correct the situation.
I tried purging the cache as suggested in the error message but I still got the same error. I didn’t know what to do next. Any advice on how to fix the problem? Thanks in advance.
Read moreHi Gurus,
I was using a newly installed CanonScan Lide 20 to scan documents and convert them to PDF.
However, I suddenly got this error message about a missing rmslanctc.dll file (see screenshot below) in Adobe Acrobat Reader.
Adobe Acrobat: Acrobat.exe - System Error
The program can’t start because rmslanctc.dll is missing from your computer. Try reinstalling the program to fix this problem.
I had lots of documents to scan and I didn’t know what to do to repair the error.
Any advice on how to fix the error?
Please help me.
Read moreHi, I was creating a keyboard shortcut for the application Adobe Photoshop CS3 in my old Mac OS x v.10.3 when I got this error message (see screenshot below).
Is this a bug in Mac? Is there a workaround for this error?
I hope someone from this forum can help, please.
You cannot add keyboard shortcuts for the application Adobe Photoshop CS3.app.
Read moreHello,
I was opening Acrobat Adobe Acrobat 8 Professional on my new Win 7 when randomly I got this error message below.
Adobe Acrobat
The Organizer database is damaged and will be reset the next time Acrobat is launched. Quit the application and close any currently opened web browsers.
It was working fine yesterday but now I couldn’t open my PDF files.
I didn’t want to reinstall Acrobat.
Do you have any workaround to resolve the problem?
Read more
