Archive
I am new user of LotusScript and Lotus Notes. Can I gather data from database using Notes View? Anybody please help me, I designed SQL (related) table for every Notes Forms, then tried to gather data using Notes Form and store that in corresponding table but I couldn’t make it. What shall I do?
Read moreI need some help from anybody on how to make and add Agent to a present database using a Java stand alone application.
As mentioned in an article I undertake the option to bring in through DXL but it doesn’t work. Is there any way to solve this?
Any help or links will be very much appreciated.
Read moreWhy is it that when I tried to open documents that I copied and pasted to Development server db from production server db is giving error like “The server is not responding with this database, should notes need to switch to a duplicate or another server” , even though old documents opened correctly in the Dev database.
Any suggestion is highly appreciated.
Read morePlease help me I am beginner in using C#. I was trying to access mail inbox in lotus notes using C#. I just need to see the subject of the mail to know whether the subject is xxx. If the subject is xxx, please inform me the steps, if possible the procedure to computerize through a web application my lotus mail inbox with C#. I need C# application to continuously check my inbox for the new emails.
Read moreI need to send two (2) applications so that when one is selected the other one reacts.
I want a calendar outlook (populated in one application) to keep posted if a person is selected from a file (based from other application).
I have been thinking to do this for sometime and have hit a dead end as the existing information/knowledge is not adequate. I don't know how to use the WDS system to send the two applications or how to make the action essential to do this. Where will I’ll be connecting using the person UNID.
Any help will be highly appreciated.
Read moreMy company just started using Quicker as a document depository. My first test was to figure out how to gathered existing document attachments for the change, but it can be made manually if necessary. The bigger problem is I need a method to let users save attachments using my new WPF application. I found a web server that gathers docs from Quicker but it's useless because it doesn't save. I'm trying to convert to WPF from a Lotus Notes application. The old Notes application contains numerous attached documents (Word, Excel, Pdfs etc). I know that there is a REST...
Read moreI need help to come up with a technique to:
1. Take away dates in xpages [client not using lotus] I am a new in using xpages with no knowledge in xpages expression language or xpages JavaScript.
2. If possible please help me also on how to compute for the Business Days in xpages since there is no xpages function @Business Days.
Read moreI need help to link a meeting (document) with a rescheduled notice sent after changing dates in meeting. I have to do this in C API and C# API Lotus. I need to check if something had changed after meeting was set.
Read moreI am trying from my ASP.NET to make an SSO to the Lotus Notes application server. Can I make an icon in Lotus notes and then create an SSO once the user logged in to my server?
Read moreI have a PHP application that sends email to the users. For most users this is just right.
However those users supported with Lotus Notes for their email client were receiving an email that show to start with the headers I enclose to the message. I have attempt changing the line ending but I can’t do it.
Has anybody had any idea why I am unable to change it? And how I can manage the email to work correctly?
Everything works with each other tested MTA, nothing works with notes.
Read more
