Archive
The Windows installer would not allowed the computer term to be the same as the user account tag. This is considered as a bad exercise and can cause trouble with device that used the system such as SQL Server. But after the installation you can actually alter the terms to compare. My question is why do Windows allow this after explicitly prohibited during the installation process?
Read moreAccording to the Gang of Four, the commitment of the template procedure pattern is to "determine the skeleton of an algorithm in an operation, suspend some procedure of subclasses. Identify the steps of algorithm without changing the algorithm's structure". What does this mean?
Read moreInheritance is the term used when a class is thus derived from a non-abstract class to make a specialized version of it while an abstract class is used as a starting point for various applications. Would it be better if we had two different terms for these thought rather using the same phrase?
Read moreThe preconceived notions restricted the performance to sympathize the ideas. This has proven to be the case for encapsulation or the inclusion of a thing with another thing so that the inclusion will become unnoticeable. Can you think of the situation in which their preconceived notions got in the way to comprehend the needs? What happened and how did they overcome it?
Read moreI have a HTC G1 mobile. It is a nice phone with all features but I face some problem in handling. The main problem is about call summary. In any other phones when I end the call the phone shows the call summery, where I can see how long I have talked in this call. But in HTC G1 when I cut my call, after ending It does not show summery of call duration. Even it does not make any notification sound when my line is disconnected. How can I solve this problem?
Read morewhat is the drawback of using linux?and also tell the advantages of using linux?
Read moreI have recently purchased a digital webcam, its plug n play; but if i access it through video chat in any messenger then the image is in black/white (Negative mode); however if i play it without any messenger then image is normal.
I have tried to access it through msn, yahoo etc..
But result is same on all messengers. Moreover,
I have gone through all settings as well but still issue stands unresolved.
Any suggestions?
Read moreI cannot either embed or link any audio file to a PowerPoint presentation. Do you know why?
Please help.
Thank you.
Read moreMy hardware is not functioning properly. I want a free hardware diagnostic software.
Do you know one?
Please help.
Thank You . .
Read moreI recently changed my anti virus to Microsoft Security Essentials but now I am wondering if I need to use an additional firewall. A friend of mine told me that MSE is just a vanilla anti virus and he actually recommended that I use Comodo Internet Security along with MSE, can this really be beneficial? Or is there a better anti virus that I can use along with MSE?
