Archive
Hi Techyv IT,
When performing back up with windows XP I encountered this problem. The error said
An occurred while performing backup task, it gives me no idea how to fix this one because the error only is on the message.
How can I fix this one guys?
Error
An occurred while performing backup task.
Read moreHello Guys I am trying to view public folders using Exchange System Manager and I get this error.
I know we have a Fully Qualified Domain Name of our server on SSL How can I solve this issue?
Please help.
The token supplied to the function is invalid
ID no: 80090308
OK
Read more
Can i have virus if i read email? If not please discuss.
Thanks, Mildred Dorato
Hi Techyv People,
Why is it Mac has a few virus issue compare to Microsoft?
Thanks,
Mildred Dorato
Read moreWe have a system which communicates with com in a computer. We use it for printing reports from the system.
I don’t know why this message appears?
I checked the computer com, and it is connected. I checked also the BIOS and com of my computer works well.
Why this message always appears when trying to print from our system?
Error
Unable to open display port COM6, please check your settings.
OK
Read moreHello! I cannot log in to WHS Outlook.
This message showing every time I try to log on as an administrator. Sometimes also as a user I cannot log in.
I tried to uninstall Outlook from my WHS and then re installed it again but error still there.
How can I fix this?
Unable to Initialize Redemption RDOSession MAPIOBJECT!
The following error occurred while trying to initialize RDOSession.MAPIOBJECT:
Error # -2079195127 (0x84120009):
Cannot complete the operation. You are not connected.
Ask your home network administrator to ensure that WHS Outlook is properly installed, and then try again. Contact technical support if this condition...
Read moreHow safe is buying laptop hardware online and where should i buy it? I want to upgrade some of the hardware of my laptop. Please tell me the best solution and best place. Please help!
Read moreMy CorelDRAW X5 Crashes. It always appears every time I’m in the middle of doing my projects in Corel draw. What is the problem? Is it on my computer system? I am running windows XP, I have 1 GB memory and I GB also video card? So I think I don’t have any problem with my hardware. Please help.
CorelDRAW X5: CorelDRAW.exe – Application Error
The exception unknown software exception (0xc0000417) occurred in the application at location 0x7858c955.
Read more
