Archive
I have an obligation to do, something like simple search advanced in Lotus Notes. I need this so the end users can filter the views by seeking criteria that gives runtime program on the customer. They don't need to connect with the designer so you cannot view the selected code. Can you please help me with some ideas, please?
Read moreI want to know your expectations for this year up to early 2012 in the society of IT trading information. Please send me your ideas and any specific subject matter that you would like to discuss or any features that you would like to add in this field. Thank you.
Read moreI have a customer that needs an implementation to a DR site using only secondary Cisco gear. Is there someone who could give me suggestions or a guide for best probable solutions, and desirable manuals for this matter? Thank you very much in advance.
Read moreI have a Netgear fvx358 working together with my Cisco 3750 switch. The Cisco 3750 will represent as the distributing switch in an organization and the Netgear will be the access switch. I just want to know if there will be no problem with the configuration of the VLAN and configure others if necessary? And also, I want to know which is more improved, the Cisco 3945 router or the Netgear fvx358? Please send me some suggestions. Thanks.
Read moreI have received a Microsoft Foundation Class (MFC) dialogue application. It is determine as a title called CMyDialog from CAxDialogImpl. I make some object and called DoModal CMyDialog, and install the application. However, I believed that the memory was leaking and I notice that the memory allocated by HeapAlloc was not released. Where is the freedom? Please help me.
Read moreI am using an HP iPAQ hx2790 for more than a year now. I am having a battery drain issue.
When I changed the battery with a new one, the same problem still occurs.
I even tried a server fix but the battery will just run for one to two hours and then it will turn itself off.
What do I need to fix this?
Please help me.
Read moreLately, I am receiving an error message from IE. The error is stating: Internet explorer caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. My Internet Explorer will usually shuts down and just close. I am running Windows Vista pre-loaded with Internet Explorer but I can’t seem to install it. My computer has a virus but my anti virus managed to removed it. I am not sure if the problem with Internet Explorer is part of the virus. How can I fix it? I still have some QuickBook...
Read moreI just need to learn and record the compatible level data of Comma Separated Values (CSV). For example, if I will get a flat data format, through this 1'SQL', 'ABC' 2 'SQL', 'DEF' 3 'PP', 'BGC'. Through this, I have to learn this PL a kind of files. If PL type as "ABC' then I'm doing any processing and writing 'PL', registration as well. After RIC in writing the record pointer will be given at the end of file, but for the second reading of my guide must be 'DEF'. How I can set my guide on 2 different...
Read moreDB2 can return SUM function apart within a declaration. If I have the following situation: POWER SELECT SUM (AMOUNT), COUNT (*) FROM table WHERE POWER IN (180002.180092) gives Rama the amount and the Count 180,002, +100.3 which I can return into two values, one is the positive values of the number and one for negative numbers yield: Branch, credit, debit, account 180002, -100, +200.3. How can I accomplish this? Any ideas? Thanks.
Read moreHow would you copy substring from CLOB field with SQL if substring from/to location are variables?
This exercise is OK (RPG free with embedded SQL):
exec sql choice substr(myclobfield, 25, 70)
INTO :mystring
FROM MYLIB/MYFILE;
[/pre]
Since this source is a failure of compilation
from = 25;
to = 70;
exec sql select substr(myclobfield, :from, :to)
INTO :mystring
FROM MYLIB/MYFILE;
[/pre]
The following is a compilation failure:
MSG ID SEV RECORD TEXT
SQL0171 30 27 Position 1 Plot 2 of SUBSTRING function is not valid.
SQL0171 30 27 Position 1 Plot 3 of SUBSTRING function is not valid.
[/ Pre]
Can someone please explain why this is not working, and please give some...
Read more
