Archive
I am having a problem supervising ESP traffic; my Cisco router is not producing NetFlow packets on the ESP traffic. How can I fix this?
Read more
I am running Windows 7 and I am having tons of issues with my printer because the point and print restrictions are enabled. Few months ago, I had the same problem but I happened to resolved the issue by disabling the restrictions on my Server 2008 R2. But I am currently under Server 2008 and the option to disable the feature are not available.  There are some settings for point and print but no option to disable and I could not even install printers on the client PC. How can I amputate the restrictions? Can someone help? Thank you.
Read more
I just want to know how does cluster computing works. Is it the same as when you submitted your work,, cluster computing will rip it by pieces and then distribute those pieces to various workstations that disperse through cluster? Or does cluster computing used only one workstation and run the entire task merely as the front work? I hope you can send me some ideas. Thanks.
Read more
Do you know How to Disassemble a MacBook? I have a MacBook and want to disassemble it. Please give me some information.
Thank you.
Read more
I am using Sudo and I cannot enter a password, I am receiving error telling me that the Wine is not mine. How can I install Adobe Flash with Wine as my root? Please help me. Thanks.
Read more
I just bought 15 songs in Rhapsody store. After downloading all the songs, I instantly clicked it on my music list, but it says the file is invalid. I went back to the Zip file that I just downloaded and then right-clicked it to extract the file. After extracting, the songs are not there and the folder is empty. What can be the cause of this? What should I do next?
Read more
I am receiving bunch of errors with Rhapsody. I already contacted customer support for both Rhapsody and Windows Media Player. When I attempt to open it again, it works fine at first. When I made a reboot and start Rhapsody again, it says I need to update some WMP components but when I run the update, it did not work. The update button is locked and I cannot click it because it is grayed out. I need to download songs but I was unable to. Do I need to cancel my subscription with Rhapsody? What can I do to...
Read more
I am trying to execute High-Performance Computing (HPC) cluster on 5 PCs but I am running out of conclusion. I heard about Clustered High Availability Operating System (CHAOS), Red Hat, Slackwave and CentOS. What I want to know is what is the best Linux distribution that can run with my HPC cluster? Where can I find some articles or information that can compare Linux distributions?
Read more
I bought a dedicated server pre-loaded with CentOS and plesk panel 9. I have information about plesk panel and Secure Shell (SSH) root connected with my VPS. I asked my technician to install Linux and he installed Linux Fedora on my computer. I had a problem running it so now I need to install it by myself. But I don’t know how or where to start. Can anyone help? I know adding or removing anything from my dedicated server won’t cause any problem, right?
Read more
I successfully installed VirtualBox 4.0.8 R71778 on my Ubuntu 10.4 64-bit PC. My problem is I could not find any appropriate driver for my network card and audio that can meet my virtual windows. How and where can I find all the drivers needed? I am using Dell Inspiron 1464. I hope someone can help me because I really need it.
Thank you in advance.
Read more
