Archive
Hello! We primarily used Zimbra for syncing emails and calendars. Now, we need to sync mobile phones to our Zimbra accounts. I successfully sync Android phones, iPhones and Blackberry but I was unable to sync Windows Phone successfully. The server that we are using has their own self-signed certificates and our client cannot afford to buy other certificates. I am receiving error when trying to set up account in Windows Phone. The error is: The server's certificate has problem. Contact your technical support. Error code: 80072F0D. How can I be able to sync with this kind of certificate? Can...
Read moreIn Exchange 2007, how can we make a Global Address Lists (GALs) and let the users to see those who are related to them? And when my server crashed accidentally, how can I reinstall Exchange when my Active Directory is still active? What is the type of the connector that I can use to connect to the internet and how I can send mails through that connector? Lastly, in Exchange, what are the methods to connect with Active Directory? I hope someone can help me as your replies will be very useful to finish my project. Thank you.
Read moreIn Excel, how can I add restrictions to a cell for editing such as only particular users can revise it? And how do I print the full path of a workbook under page header?
Any help will be appreciated.
Thank you.
Read more
What is NTFS and FAT32 use in the Operating System?
Thanks,
Hero Angeles
I used Excel for computing daily expenses and profits. Lately, I’ve been encountering problems and since I only knew some basic functions in Excel, I could not resolve it by myself.
My problem is, I don’t know where and how to customize the decimals that I put on each cell.
When I insert 198 on cell A1 and hit enter, the output will become 1.98.
How can I fix this?
Read moreWill it cause problems or errors if I install various Exchange Server 2003 within the same organization? And also, what are the benefits of installing unattended Exchange installation? Thanks.
Read moreI want to install Exchange Server, but prior to this I need to know when do I use the Setup.exe /forestprep command and the Setup.exe /domainprep command?
Do I need any permission to run the two? Thanks.
Read moreI want to install Exchange, what are the system requirements needed such as type of RAID array, adapters, processors etc. And also, can we install Exchange on the same device where domain controller is?
Lastly, what are the preparations needed for the Active Directory schematic representation before installing Exchange? Any ideas?
Thank you.
Read moreHello! I’m a little confused with the differences between Exchange 5.5 and Exchange 2000/2003; can anyone explain the differences between the two? And what is the Network Infrastructure (Bandwidth and Latency, Usage, Messaging System, Location of Servers) when installing Exchange 2003?
Read moreI want to install MS-Messenger for Mac 8. I’m a new Mac user and I want to know if I can do audio and video calls with it? Can I use the messenger for Live Communication Server 2005? Any help will do. Thanks.
Read more
