Archive
Hello Experts! I have a question about cloud servers. I just want to know how they provided an outcome expeditiously. Assuming a data that has accurately 1000 terabytes in a website servers and it is a bit pricey to run it in a data storage device such as Solid-State Drive. Are there any ladders that are used to hide the delays that are typically acquired when processing network data? How long will it take to transmit data with the server? I hope you can send me some ideas. Thank you.
Read more
Hi Guys,
Please help me on my problem because i'm just new in the site if it work thanks a lot in advance. Here is my question: Suddenly, all the browsers installed on my laptop were unable to open certain website. I am using a router and I can connect wirelessly and open those sites with my mobile phone and desktop PC. I don’t see any errors on my browser except for a white blank screen that keeps on loading. When I pressed the enter key, the loading will stop. I really have no idea and I need help...
Read more
I am using different servers on my machine.
And I need to upgrade those servers to Lotus Notes 8.0.
I am currently using Lotus Notes 6.5 and I need to know if it is possible and how will I achieve it?
Please help me. Thank you.
Read more
My boss gave me 250 distribution lists for deletion. It will be very strenuous to search it one by one in AD User and Computers (ADUC) list. But the only way I know is to delete it that way. Is there anything that I can do to make my job faster? And also, are there any risks when deleting numerous distribution lists? Kindly please help me. Thanks.
Read more
I have 1,500 computers on my Active Directory list. I want to delete those who are not able to log in for the last few months. But my problem is I don’t know much about AD and I don’t know where or how to locate various computers in Active Directory. And also, I want to make my work fast. Is there any tool that can illustrate some ways to insert multiple computer names? Please help me. Thank you.
Read more
The clients are complaining that they could not locate windows update and many more. So I want to provide a support for clients on another forest. I know I need to install the Server Locator Point since it is essential to Configuration Manager hierarchy for helping clients find the information via AD Domain Services. But my question is from which forest do I need to install Server Locator Point? Will I install it on the SCCM server or in the client’s forest? Does anyone have an idea? Kindly please help me.
Read more
In the field of SAP Human Resources or SAP HR, what are the infotypes needed to create when appointing OR PA40 that you cannot retain later on with PA30? And also, what are the processes or scheme that we can use to prevent errors when generating various positions manually? I need your precise replies.
Thank you.
Read more
I was searching for a tool or program that can make my Windows XP Start menu to look like Windows Vista. When I found it, I tried it on my computer but I accidentally closed the window where I downloaded the tool. Due to some issues that I’m encountering, I decided to remove the tool.
After which my problem arises. When I was about to clear my recycle bin, I noticed that I can no longer opens the window of the recycle bin to its maximum size. It always opens as a small window in which I have to manually...
Read more
My wife is running Windows Vista with MS-Office Home and Student Edition on her laptop. The problem is, every time she started using her laptop, MS-Office will appear on her startup screen, demanding on my wife to configure and install the program.
She already installed MS-Office on her laptop so she always chooses the cancel button. But doing this will cause other programs to stop working. What can be the cause for this? If she hits the restart button, everything will be fine on the next reboot.
Then the next time, the same thing will happen repetitively. Please help me fix...
Read more
I am running Windows Vista Ultimate. When I opened my task manager, I can only see the programs that are currently running. Aside from that, there is nothing more.
The tabs are missing and other options as well. The active Processes, CPU usage and Physical Memory are also missing. What is causing this? If this is another issue in my registry, how can I fix it?
Please help.
Read more
