Archive
I want to draw a table using HTML only that contains 100 columns and 30000 rows, I don't want to draw them manually using and , I am seeking something that can do it like or something like that. No use of JavaScript or any other language.
Thanks for a quick answer
Read more
Hi All,
How can i find what service pack i have for Sql 2005?
What's the easiest way and with select statement how can i find?
Thanks
Read more
I am choosing between the iPhone and BlackBerry smartphones. I've been using a low-end phone ever since and would want to change it since I will be needing it for my travels abroad. But I could not decide on which of the two is better in terms of features and which will be useful for my business. Can someone compare the two to help me decide which one is really the best? Thanks.
Read more
Hello experts,
 In a small office we had our previous server is Windows Small Business Server 2003(SBS 2003). We are trying to have a migration in our data to new Windows Small Business Server 2008 because some of its new feature is really needed in our database program. Going back, after a full installation, configuring network address, and some configuration of this new server, we launched the DCPROMO in SBS 2003 and got a message box Active Directory Domain Services Installation Wizard. We try to isolate the said trouble in physical network connection but no luck. Please help...
Read more
Hi Techyv,
I can’t really understand why my mirc719.exe could not start as compared to my friend laptops that can response easily.
How can I resolve this problem because I really need to communicate with them as soon as possible?
Please give an advice.
Thanks in advance!
iogk1t
Error:
Blocked: wine start/unix
The file ‘/media/DUMP/Downloads/mirc719.exe’ is not marked as executable. If this was downloaded of copied from an untrusted source, it may be dangerous to run. For more details, read about the executable bit.
Read more
Hi All,
I thought installing VMware in Feisty fawn is easy to handle compared in my other operating system which is Windows XP service pack 2. As I start the VMware gives an update pointing the kernel header 2.6.38-10-generic were not found. As click refresh button nothing happens. I’d Click Browse button with no idea locating that kind of file. Can someone out there guide me with these VMware Kernel? Thank you Techyv.
VMware message:
VMware Kernel Module Updater
Before you can run VMware, several modules must be compiled and loaded into the running kernel.
Kernel...
Read more
Hello Experts,
I was unable to proceed to play the videos downloaded in my laptop Toshiba L500. This is ridiculous why is it can’t play this video even I have software VLC media player that computer shop attendant installed it. I’m freeze with this media plug-ins, do I have to cancel this dialogue box appear in my screen because I’m afraid that this might ruin the other programs. By the way the videos that I like to play with is divx format. Please help me with this problem. Thanks in advance!
Plug-ins appear in my screen.
Xubuntu codecs manager Read more
I have searched everywhere for a possible solution to my problem to no avail. The error that keeps appearing when I am attempting to install MS-Office 2010 is: Error 2203. An internal error has occurred. I tried for almost 5 times to install the software but the error just keeps on appearing. How can I fix it? I am running Intel Core 2 Duo with Windows 7 Professional. I hope someone here can help me. Thank you.
Read more
I purchased a brand new Toshiba A200 laptop. It has 4GB RAM, Dual Core Processor and running with Windows Vista 32-Bit OS. I downloaded Adobe Photoshop CS4 few months ago which I primarily used in my job as a designer. It was working fine until last night when I was painting an illustration; an error keeps popping up that is so annoying.
The error is: Adobe Photoshop CS4 Extended could not complete your request because there is not enough memory (RAM). I am completely lost so I checked on my available RAM but...
Read more
Hello Everybody,
I was having Windows XP to be a dual boot with Feisty fawn. As a new user I’m getting error with my Feisty when tried to perform Add/Remove application. I’d follow some basic guide on updating and installing then I tried to input it into the terminal.
I do run first sudo apt-get update and followed by sudo apt-get install –f but no good output. I don’t have an idea of changing source list. Below is the error message.
Any help would be greatly appreciated.
Thanks!
ANd9GcR_FX91A6a-Xk5ZHtBflDz2VvYRiw90tXbRDntW2xt8tGzMDDpVkPFIk963
Error:
Failed to check for installed and available applications
This...
Read more
