Archive
After upgrading my Mac to Snow Leopard, I created an Exchange Mail Account and have gotten my contact working.
However, I cannot access my calendar online. When viewed on iCal, I can see the Exchange account and the information it has appears to be complete. I Just could not get it to go online. Do you have any suggestions how to get calendar to work?
Read more
I need some clarification on Microsoft’s client access licenses. We have a Windows 2003 server and chose the per-seat licensing of 50.
Do we also need to have 50 Client Access Licenses (CALs)? In addition, for Exchange 2003, do we need to acquire both Exchange CALs and Outlook CALs and will having Exchange CALs suffice?
Thank you for any information you have on this subject.
Read more
Hi...
can anybody tell me that what is macro and how to use it in excel?
thanks in advance
Read more
I am using Windows XP as my OS, and it is attacked by a virus and the result was only a green screen appears.
I have executed ‘Spybot’ more than two times and it had deleted lots of files.
But, I am not able to connect the internet and there is no way to get updates. I have to reboot the system in safe mode, but it is not allowed to scan the computer.
Also, it gives an error message which says that ‘ntfs.sys file is missing from the ‘drivers’ folder under ‘system32’.
I have run the Windows Repair by using the installation...
Read more
I am using Windows XP Pro computer. I am facing a problem with that sometimes I am getting an error message. The error message is like that ‘Fatal System error. The Windows Login stopped working.’ Then it is to be restarted by pressing the reset button. Please help me to fix this issue.
Thanks in advance.
Read more
I am facing problem with the internet connectivity in Windows XP computer with the LAN line.
I have searched in lot of forums to get help, but nothing found.
I am getting an error message ‘the dependency service is not available.
It shows the error code 1075.’ I have done something with the Windows installer CD, but there was no change in the result.
I have also executed the system restore and checked with the safe mode.
But, there was no use with both of the actions.
Please help me to get rid of the problem.
I will be thankful for all the help and support.
Read more
When I am trying to download anything it show me an error message which says that ‘run time error – 81 . 339. Failed to expand shell folder constant of the user due to internal error. Please help me to figure out this problem.
Thanks in advance.
Read more
When I execute an agent within a database which will open another database and it will display some fields, I am getting an error message. The error message displays that ‘Database intranetsevicio.nsf is not able to open’.
Please help me to fix the problem.
Thanks in advance.
Read more
I have some web services which is written in Lotus Notes Domino R7. When I am attempting to access the database from other Domino server, I am getting an error message which displays that ‘database is not able to open yet’.
I have signed the Web service with Lotus Notes ID for executing an agent in the Domino Server. I am the user of Lotus Notes Domino R 7.
What changes are to be made in security settings to solve this problem? Please help me. Thanks in advance
Read more
Hi Exchange experts,
Error with Exchange 2007
I am an OWA user. When I am attempting to attach any file, an error message is coming which displays that ‘There is no space available in the disk.’ I am using Windows 2003 server and installed Exchange 2007.
Please help me to figure out the problem.
Thanks in advance.
Read more
