Archive
I have been working online for 1-2 years as a freelancer. I have come across some jobs that either need PDF files to be edited or data collected from them. I having difficulty collecting data from PDF files because one can't edit them or cut and paste data. So, it's become a very time consuming job. What I could have done in 30 minutes takes more than 60 minutes, so its very important that I find some tool to edit PDF files.
Can anybody help quickly?
Some advice or some reference to any software that I can use to convert or...
Read more
Hi experts,
I have never used Apple's Macintosh Operating system. But I have heard that it never gets affected by Viruses!
As a user of windows OS, it is really hard to believe that an operating system never gets affected by viruses.
How is it possible and what are the reasons of too much virus in Windows Operating System?
Is there any possibility of any new virus that will attack Macintosh operating system?
Please tell me in as detail as possible.
I am using windows operating system XP service pack 2. I want to setup password protection to my individual files and folders but I don't know any way how to setup password protection for individual files and folders. In windows XP, is there any tools to setup password protection for files and folders? I want to know please tell me and can anyone explain is there any same tools in windows seven?
I am willing to use windows seven in future so I want to know how can I use password protection in that system. Do I have...
Hello!
The following databases are running on my computer:
Informix DNS 10.00FC8 with Linux RedHat
MS SQL Version 2008 Express running on my Windows 2003 R2 SP2
And lastly, I am running IBM client Version 3.5 TC4 when connecting with Windows Server to Linux. I configured the Informix and linked the server to SQL with the help of OLE Database for ODBC. It was working but it failed on completion. I need to use the OPENQUERY in SQL to make it work flawlessly. I want to know if it is just fine to and if OPENQUERY is working better than selecting it in...
Read more
I have experienced difficulties in managing my PC now. I found out that some of my important files were lost, eventually crashed, and performed slow.
There's something happening in my computer, that I don't know. Since, I am the only one using it and I can't remember if I manually deleted my important documents. Is there a possibility that a virus is the cause?
If this could be the cause, how to avoid the virus?
I mean, how to make my computer free from viruses? Is there anybody who can give me idea on how to...
I've made a little progress with packaging and making a runtime file for my Access 2007 app using Microsoft info pages. But for some reason, I'm getting a blank application when I test-package it and then tried and run the file.
Basically, I created a private certificate using Office Tools, did a "package and sign" inside Access, then (as advised by MS) changed the file extensions to .accdr, created a shortcut and edited the shortcut executable so that it had /runtime at the end.
What actually happened is that it opened up a blank environment, but with the...
Has anyone had any success with ePrint, when email is sent from within Apple's iPhoto?
I have a Photosmart Plus, B209 model. Printer Status in HP ePrint center is ready & connected.
Sending email with photo attached from the gmail web interface, works as expected.
Sending the same photo, from within iPhoto using the "Share via email" function and using the same Gmail account, results in job failure with the remarkably unhelpful error, "system failure" reported on the Job Status screen, in the ePrint center.
Any suggestions or any known issues would be appreciated. Search of forum doesn't show any threads referencing iPhoto specifically, although some...
Read moreSometimes I see that the CPU usage shows 100% or around 100% though no program is running. What might be the reason behind this problem? Many times I have seen this as I use Windows XP service pack 2 what am I supposed to do? It makes my PC very slow, as my processor always looks busy for some thing else, I don't know.
I can't figure out the reason behind this problem. So I can't do anything to solve the problem. I need immediate assistance to solve this problem please. Some one quickly answer my questions and tell me...
Read moreI have been thinking about the AMD processors I heard that they are much cheaper and same as power as intel processors so I intend to buy a AMD processors but the problem is that my Motherboard is Intel DG41. Now the question is that can I use the AMD processor in my Intel Motherboard? If not then I will have to change my Motherboard also this will be really a costly job for me. So if it can be used then it can help me out.
What i have to do to upgrade my Bios of my laptop??
my laptop is older and now its model must be out of market so how can i get update for my laptop? is there any way to get it?? where can i find the other drivers for the hardware of my laptop??
the drivers are out dated so its really necessary for me to get some update for those hardware.
so some one please give me some reference of some sites where can i find those software updates.
My laptop's model is HP...
