Archive
Hi there,
I have got installed MS windows vista on my PC and I am having an issue with it while trying to send the fax.
The issue is, I have made a MS word 2003 file (commanding) go FILE > SENDTO > FAX, and it follows the wizard but at least when the wizard ends, the FAX has not been started to send.
Mean, whenever I start the FAX sending wizard from a word in Window Vista, the wizard starts and then ends without sending the Fax. I am very disturbed due to this issue and have tried almost everything (which I know) but no use.
To fix this issue, I have...
Read moreI have a laptop and its model is "HP Compaq NC 6000". It does not have WiFi support but is has wireless connectivity.
I get some wireless network signals from my home and I configured them myself. The operating system of the laptop is Windows XP service pack 2.
When I configure the connection, a notification message comes, that I have got connected. But when I try to use the same setting in my browser, the browser can't find any connectivity!!
Can anyone tell me what the probable cause of this problem is? Can you also suggest ways to get connected to...
Read more
I'm working as a software engineer, I'm using a laptop in office use, for 8 hrs continues, my laptop has 3 - 4 years of old, it producing more heating, can't able to keep my left hand, that much heat coming, what shall i do? I already bought an cooling pad but it is not working properly I can still feel the abnormal heat. Any health problem will come because of this heat? Kindly anybody guide me.
Albert
I am learning to code with C++. I was wondering if I can return multiple variables from a C++ program, instead of declaring as global, if possible. Suppose I have a function that works on 3 integers; do some process on them, I want 3 of them to be returned.
Read moreI would like to get a second opinion on an issue I'm having with a Acer Aspire 5050 Notebook.
Seconds after I turn it on it shuts down suddenly (after passing the POST screen).
I've noticed that the CPU fan isn't working and cause overheating problems.
So is the faulty fan causing those sudden shutdowns right after I turn the laptop on or could the problem lie somewhere else?
Read moreHey experts,
How are you all?
Firstly I want to share you one thing that I don’t have much knowledge about, computer networking. That’s why I am searching for help from here. I had one PC in my room. Recently one of my friends begins to live beside my home. He also has a PC.
I use a Wimax internet modem for my internet connection. It has 1mbps speed. So it is enough speed to share with another PC (512kb/512kb). I want to share my internet connection with my friend, who is living beside my home. But the system to share a...
Read moreHey buddies,
I have a Compaq mini 110 with Windows XP installed. I accidentally compressed the hard drive when I was trying to get some free space, so XP didn't start anymore.
I'm trying to do the Disaster Recovery based on the instructions in my manual. I've created the Disaster Recovery boot program (SP42226.exe) for my USB memory stick and it starts the Roxie BackOnTrack program. But the problem is, it asks for a "Restore Set" (*.SIB_DR) and I can't find files anywhere. Should I create this file when the OS was working and back it up to an external...
Hi all,
I am having problems removing a data file in oracle database. I removed it but when I tried to make one with the same name then it said that "data file already exists".
But how it can exist when I personally deleted the file?
Can anyone help me?
Read moreHi Friends,
