Archive
Hello experts,
Hope all of you are quite well. I am experiencing a new sort of problem. My system time is not showing correctly. When I synchronize the system time with the current time, it only endures for the time I run the pc. If I switch off the pc it becomes incorrect again and again.
I have been suffering a lot of problems for this Time error. Some of the software are not running if the time is wrong. So this TIME ERROR annoying me so much. Moreover, a message is showing at the time of stating windows saying that...
Read moreHello,
Friends I got a problem with my keyboard. Since last night my keyboard has not worked. I don’t know why it is happening. It’s a new keyboard which I bought last month. It’s a ps2 keyboard. To find out the problem, firstly I tried another ps2 keyboard on my PC, but I got no luck. Then I tried a USB keyboard which also not working. Then I tested my ps2 keyboard on another PC. This time it was working there. But it wasn’t working on the PC.
So, definitely the problem was on my PC. I don’t know that it is a hardware problem or software problem. I am unable to find any cause which...
Read more
Hi friends,
I have a clone desktop pc (p4). I bought it about 4 years ago from a local computer shop. One day when I went to the shop I saw the manager of the shop was starting their main pc. The most impressive thing was that when he started the pc, I noticed there a logo and the name of their shop was showing at the top right of the bios screen (the black screen which comes at the time of starting/booting a pc). I was impressed by this sort of technical thing.
I don't know...
Hello friends,
I have been using a desktop pc since 2005. I have an old Samsung monitor which came with that pc. I always wanted to change that monitor with a LCD monitor. Recently I have bought a LCD TV. But it doesn’t have any VGA import jack through which I can connect my pc with the LCD TV.
I don’t want to waste my money in buying another LCD for my pc. I am looking for a system that will help me to use my LCD TV as a LCD monitor for my pc. I don’t know anything about the...
Read moreFriends,
I hope all are quite well. I have got a problem with my motherboard. It’s an old p4 motherboard. It doesn’t have any SATA jack except ID HDD cable jack. I have been using a 120 gigabyte Hard Disk for a long time.
It’s a very short space for my recent works. I have a habit of keeping so many songs, videos, software and other important things in by Hard disk. But this short space does not provide me enough space to keep those things.
For this reason I have bought a new 500 gigabyte HDD. But is doesn’t support ID. It’s a SATA hard disk. So,...
Read more
Hello Friends,
I have got a problem with my Ulead Video Studio 10. Recently I am trying to make a picture presentation which will be a video file. That’s why I have collected the Ulead 10 video editing software. It’s quite easy to handle and operate. Firstly I imported some JPG files (about 80 files) in the software.
After setting up all effects I wanted to see a preview. When I hit the preview button, my PC began to hang and...
Hi All,
I am running MS windows XP on my Intel Pentium 4 PC. I am facing an issue while using my video and audio file converter program/software. Actually, I have installed Format Factory (different formats converter tool) software on my PC to convert different video and audio file into other different (audio and video) formats but when I try to convert any file to .
AVI format via adding concerning file in Format Factory, everything goes well but at the point of selecting output quality the dropdown list of quality option does not appear or after...
Hi Friends,
I have got a problem while installing the Windows XP on my desktop pc. I have already tried for three times. But I was failed to setup it. I have gotten the following errors.
1. Fatal error installation failed:d:1386asms
2. One of the components that windows needs to continue setup could not be installed.
3. The parameter is incorrect.
4. The request could not be performed because of an i/o device error.
I don’t know anything about these errors. Could anybody explain me about these errors and how to get rid of these problems?
Thank you very much.
Read moreHi friends,
I am having a big trouble with my PC. I am seeking for some help from here. My PC is not booting at the same time while I am pressing the CPU power button. It begins to start approximately after 20 minutes. What a peculiar problem it is. Moreover, sometimes it hangs on the first screen (boot time).
To get rid of this problem I opened the CPU and changed the CMOS battery. But I found nothing special. Then I changed my ID cables and power supply. No change. I did not know where the problem was. Please anybody help me in this...
Read moreHi buddies,
I have a Desktop PC (Intel Pentium 4, 2.26 GHz processor, 256 of ram with Windows XP home edition SP2). I have got a problem that; I am always getting the Memory low error when I load the windows. I have tried many things including RegCure, Registry cleaner, system mechanics and other error fixing programs. I also ran a defragmentation on the total hard disk.
But the problem was not being solved. Moreover, if I reinstall the operating system, the problem comes again after some days of installing. I watched this on both user’s and administrator’s accounts. I don’t know what I should do now. This problem...
Read more
