Archive
I have been using CorelDraw suites version 12, and have just bought a license for CorelDraw X5 Student and Home and installed it successfully.
However, when using Windows 7 own default program changing app I try to make PhotoPaint as my default program for jpg, BMP, gif etc. I get a error panel saying:
Unable to initialize Visual Basic for Applications
VBA may not be installed.
Try reinstalling it using the Corel Installer and selecting a Custom Setup.
  •  I have tried this using Modify and then Repair but still i'm getting the same error.  I can successfully associate CorelDraw...
    Read more
I have a Windows XP bootable CD. This is service pack 2 edition. I want to set up Windows XP with this CD.
But a problem occurred. I lost my serial key for this CD.
Right now I am not accessible to shop where I can buy a new CD.
Is there any way to setup windows XP with that CD without entering the serial key?
Can anyone help me to overcome this issue?
Read more
I get this error in my Windows 2008 server machine:
Windows could not search for new updates
An error occurred while checking for new updates for your computer.
Error(s) found:
Code 80072EE2 Windows Update encountered an unknown error.
Get help with this error
Thanks in advance.
Read more
I have been having a problem with my D-Link wireless router lately. When I tried to diagnose the issue with Windows Network Diagnostics, it shows the following message: Windows tried a repair but a problem still exists.
Cannot communicate with Primary DNS Server (IP REMOVED).
Network diagnostics pinged the remote host but did not receive a response. Reset the network adapters "Wireless Network Connection" Resetting the adapter can sometimes resolve an intermittent problem.
Can someone please help me?
Read more
Hello brothers,
Why is this happening all of a sudden. how can I fix this. I cannot afford to replace any spares not can I buy a new one.
Its a old P III desktop and was working fine till today morning.
I haven't added anything new nor.
Hardware malfunction.
Call your hardware vendor for support.
NMI: Parity Check/Memory parity error.
The system has halted.
Any help is of great use to me.
Read more
I know a good amount of computers, but I'm not knowledgeable enough about audio cards. I'm currently running a Dell Inspiron 1501 and have full factory default hardware and settings. One day my volume controls gone.
I rebooted my computer, and it's still not working. And so I installed my audio driver and rebooted then reinstalled the driver with another reboot, but it's still same. Actually I repeated the process 6 times, 3 from installing the CD provided by Dell and 3 times from dell still the same.
I finally decided to do an OS repair, it took 24 hours and got...
Read more
Google talk has issues.
Could not connect to Google talk service (error 1).
Connection Error
Could not connect to the Google Talk service (error 1)
Learn more
I have been getting this for a while and using yahoo messenger but would need this working as i have many of my friends there. Is there a fix for this. is this a known issue.
I was Goggling and landed in this site which has a lot of other issues handled but not this.
Can any of the experts help me please.
Read more
Hi Mates,
I have office 2007, and i get the below message when using outlook.
For a few weeks though it will go away but now its been high time i take experts advice to get rid of this issue.
Would need some solution that can fix this issue.
Microsoft Office Outlook
Error:
A data file did not close properly the last time it was used and is being checked for problems. Performance might be affected while the check is in progress.
Bye
Kanaka
Read more
I am a programmer and I am facing a problem while using the Visio document. I am writing my codes on c# and using custom templates, stencils, and masters of Visio document.
I am coding a programmed that will take Shape Data information (properties, labels, values, prompts, etc.) and/or external data information of a shape on my chosen template.
During my work I dropped the shapes on a Visio 2007 page and I can get which shapes are on the pre-defined page.
However, I can’t find a workaround to take the properties of a shape on my code in C#.
Code: Read more
Hi all,
I have attached the screenshot I took of my laptop with my mobile for anyone to help me sort this issue. A problem has been detected and windows has been shut down to prevent damage to your computer.
The problem seems to be caused by following file : SPCMCON.SYS
Page_fault_in_nonpages_area
If this is the first time you’ve seen this stop error screen.
SPCMDCON.SYS PAGE_FAULT_IN_NONPAGED_AREA
A problem has been detected and Windows has been shut down to prevent damage to your computer.
The problem seems to be caused by the following file: SPCMDCON.SYS PAGE_FAULT_IN_NONPAGED_AREA
If this is the first time...
Read more
