Archive
I have lost important data from my laptop's hard drive. I tried to use data recovery software, but I was unable to restore them. I need the right solution. I am 100% sure that my hard disk is working fine, but I accidentally formatted one of the partitions of my hard drive. I checked the recycle bin, but my data was not there.
What should I do?
Read moreI have a very important file in my laptop that I need to access. But the problem is, I forgot my administrator's password. I tried to login using my other username that has only limited access. Still. I failed to login even after I restart my computer and run it in safe mode. It is useless because I don't have an administrator account that I can use to login.
My folder is in-accessible in any way. I'm really running out of options here.
Can anyone help me on this.
Read moreHi,
I have saved all the videos and images from my canon digital camera to my pc. But now I want to write the videos and images to the cd. So, please tell me the step by step process to create a project of my all videos and images onto a cd.
Please help me and I'll be thankful to you for your kind help. Eagerly waiting for your help.
Read moreHello,
We have a finance application, that has many buttons and controls. There is a screen in the application that shows a lengthy list of reports in a big List Box. Every time we need to run a report, we have to scroll and select the required reports. This is taking a huge amount of time as we have to dig through this list.
I have heard that you can write a program that could send commands to another application. What I want to do is to write a small program that will accept a list of reports from...
What is a Wimax network?
What is a WiFi network?
What is a GSM or CDMA network?
First i have to know what are those different type of networks what are the basic definition and difference between them.
I basically understand that in cell phone network mainly GSM and CDMA is used and some Mobile operators supports WiFi technology. But i have no clear idea of how it is done and what are the differences. All those network are wireless and works on signals or frequencies. But not all device supports all type of frequencies...
Following Error shows on my PC:
1. 1720-SMART Hard Drive detects imminent failure.
2. Failing Drive: PATA Device 0
3. Failing Attribute: 01
HD detect Imminent Failure
4. To minimize the risk of data loss, backup the contents of your hard drive and run DPS Self-test in F10
Is there any solution as a result of F-10 pressing nothing happen?
I am working on a project in Excel/VBA and am unfortunately got stuck in a technical issue.
In fact, I am trying to develop a loop as I want to check for a cell and on the other hand the cell contains nothing, I want to populate some data into another particular cell.
If I would tell you in context then, it would be as like I want to check cell f1, if it is not empty then I would like to enter the VALID in a specific cell (suppose) G1. But when f1 should be blank/empty then the G1 would likely...
Read moreHi,
I have some experience of some start up problems. Some times the system halt and appears a blue screen or may show nothing this is really frustrating for anyone.
I also have experienced this problems but i don't know about the reason of this problems. Why those happens can any one explain it to me?
Is it possible to skip this problem and regain access to my system? Or there is some other way to solve this problem?
Please tell me about those reasons and the remedy for this Start up problem. Its very important to me as i have to face...
Read moreHi there,
I am still in learning process of Dos and I am having an issue while preparing/creating a batch file. The issue I have is that I have developed a batch file, which has got the capability to find lots of file and can copy them into a specific patch/folder.
Whenever, I provide the input as a month in question it goes to find all file except .docx files. Mean my created batch file finds everything else a .docx file.
To solve this issue I tried confirming that this is not so much old dos file (because may be old dos...
Read more
