Archive
What are the different Networking devices and explain each and every function and related OSI model layers.
Read more
Hi friends,
I am having a lot of problems with my flash drive. I don’t know if it is a problem of my flash drive or my system. I cannot copy files from that flash drive to my hard disk drives. But files can be copied into that flash drive. It’s a very embarrassing situation for me. Moreover, it is not being formatted in my PC while I am trying to format it. This is a new flash drive.
I bought it just few weeks ago. So, probably the problem is not in the flash drive (I am not sure). Sometimes...
Read more
My office is using 2 MB ADSL internet connection and there are more than 20 users and less than 50 users at the office. I was wondering whether I can block some websites or not. Although the office already has an internet connection, with speed up to 2 MB, apparently it's not enough and the users always complain that it's very slow.
I happened to find out, that some users open sites such as YouTube and other video streaming and I think that's what makes it very slow, because all the bandwidth went to the streaming sites. I want to...
Read more
Hi All,
Outlook 2003 send and receive goes on running and never finishes.
I am an administrator in a banking firm. We have 100 systems out of which a managers system keeps running with time that is not realistic at all.
Can anyone help with a solution. it does download but the time shown is not realistic and concerns me.
Outlook send /receive progess
Outlook Send/Receive Progress
1 of 2 Tasks have completed successfully.
Well in advance thanks.
Read more
I am using W# ith Microsoft .Net Framework 3.5. I am writing a desktop application for calculating variances in a set of values. I have read about the new Microsoft .Net Framework technology called Lambda functions.
I tried this in the application where I had written a loop to find numbers that are fully devisable by nine. The application compiles correctly, but when I run the program I am getting a runtime exception. Is it because I am now using a lambda function in the program?
Read more
Svchost.exe error referenced memory at '0x00003771'
The instruction at "0x0095f89d" reference memory at  "0x00003771".
The memory cannot be "written".
The instruction at 0x0095189d referenced memory at 0x00003771
svchost.exe - Application Error
The instruction at "0x0095189d" referenced memory at "0x00003771". The memory could not be "written". Click on OK to terminate the program. Click on CANCEL to debug the program
This happens on my Windows XP machine and not much could be found on other sites. So decided to post a question here
Thank you experts
Read more
Sound drivers have issues. This window pop's up when I try to play a song. This happens when I open the sound icon as well
Bad Directsound driver
DirectSound output v2.2.8 error
Bad DirectSound driver. Please install proper drivers or select another device in configuration.
Error code: 88780078
                                                            OK
Thanks in advance for the help.
Heard about this site from a friend and expect...
Read more
Hello Guys!
I have been given a task by my boss to solve this problem.
All the computers, both desktop and laptop are automatically backed up to the server when they're connected to the network. And every night, the server is being tasked  to tape backups. The problems are the laptops assigned for Finance Head and HR Head. Their laptops contained very sensitive files that need special treatment. And if it's possible, backup to another hard drive and not to the server.
I need an encrypted Removable Hard Disk Drive or other similar devices like that,...
Read more
Hi All,
Back with another question. Expecting your help.
When i am trying to install Office 2003 professional edition get the below error. I am not running in safe mode i am sure.
The package is working and i am sure.
Any views guys.
Microsoft Office Professional Edition 2003
Error 1719. The Windows Installer Service could not be accessed. This can occur if you are running Windows in safe mode, or if the Windows Installer is not correctly installed. Contact your support personnel...
Read more
I'm new in using Virtual Box and wondering, if you guys can help me setting up in Linux. I'm currently using Mandriva for the Linux workstation.
I have downloaded and installed VirtualBox, without a problem in Mandriva. I don't think it would be a problem, if I'm using DHCP. But the problem is, I'm using IP static on the network. So to connect to the internet, I have to setup DNS inside VirtualBox.
I have tried assigning IP static inside the VirtualBox workstation, but it cannot connect to the internet. The internet connection can work properly on the host though. I'm using Mandriva as the host and inside the VirtualBox, I'm using Ubuntu.
I have tried to change network...
Read more
