Archive
Hello friends,
I am having a serious problem in my PC. I use windows XP service pack 3. It’s about 3 months ago when I setup that OS. It was quite well till last night. But, today am getting too much problems with my operating system.
It became too much slower than past. The task manager window is not running. I use ctrl+ alt+ delete to call task manager. These keys are not working. When I try to call task manager by right clicking on the taskbar, it is looking as it is disabled. But I didn’t...
I use windows XP service pack 3 all the time. But it does last long. It becomes slower day by day. I use Avira free antivirus to protect my PC from viruses. It does not give so much memory pressure on the ram. After passing several day form installing the XP, every program becomes slower.
They take so much time to start. I use System mechanic and other PC speed booster based software. But I get no result. I do not know what is the real problem? I have changed my hard disk and Ram. But it is as same as the past. It still takes...
Friends,
I have been using the McAfee anti virus from last month. It scans well but, I think it gives too much pressure on my ram. So I took the decision to replace the anti virus with Avira antivirus. I collected a Latest antivirus from one of my friends. I installed it as normally as everybody does.
Then I went to the control panel’s Add or Remove program menu to uninstall the McAfee anti virus. But I failed to uninstall it. It was not behaving normally. It was denied to be uninstalled. After some time I looked that my PC was becoming slower. So, I felt the...
Read moreMy PC was freezing at the time of installing windows XP. Some days before, I took the decision to set up my operating system again. It was because my system became too much slow.
I usually use windows XP service 3. The last day I began to setup XP. I use bootable XP disc. The first time it started normally. At the 2nd phase of setup, I mean when it requires for the serial number, suddenly my system got hanged. I tried for many times to setup xp. But when it reaches at that phase, it freezes. Then I thought I might be an...
Read more
Ps2 ports are not working on my motherboard. Some days ago when I turned on my PC, I saw the mouse and the keyboard was not working. I thought it may be a loosening problem of their cables.
Then I unplugged them, from the ps2 ports and reconnected them into their ports. But, I got no result. Then I tried another mouse into that port. But I didn’t get it repaired. Then I became sure of that my ps2 ports are damaged. I do not know how to repair them. So my keyboard and mouse became useless. Instead of using a ps2 keyboard and...
Hello all,
I do not know whether it is a problem or not. But it looks a problem to me. My folder option is looks like it is disabled. Yes, it may be disabled, because when I click on the folder option from the view tab, it was not showing. I don’t know that how it becomes like that. I have searched on the control panel, but there is no item which shows the enabling and disabling option of the folder option.
I need the folder option to see some of my exclusive private files. But now I am unable to...
Read more
Friends, I use Windows XP Sp 3. I have some private files on my PC hard disk. I use to hide them by just picking a tick on their properties window (in the hidden tick box). Recently I am having a great problem that my has hidden files are not showing while it is enabled from the folder option menu.
Every time when I am making it enabled on the folder option menu, it is becoming disabled automatically. It is really an unexpected situation for a PC user. I didn’t see this at first. To make this enabled, first of all I have restarted...
Hello everybody,
I got a problem with OBML files. I use Opera Mini mobile browser as the default internet browsing app in my mobile.
I save several important pages while I browse them through Opera mini.
Opera mini mobile browser saves the page on *.OBML format. It is quite well-off for mobile to recall the pages.
But I failed to open these OBML files on my pc.
I tried several sort of software to open that OBML formatted files.
I searched on internet with the key word “how to open OBML files in pc”.
But I did not found any such software to support OBML files.
So,...
Read more
Hello every body,
I have got a new sort of problem on my desktop hard disk. I have a (*.vob) file on a drive of my hard disk which is very important for me. It was video file. I do not have any backup of that file.
At the first time when I copied it from a flash drive, it was quite well. Some days ago, when I played that file it was not running to its full duration. It began to stop when it reaches at 2 min 41 seconds. I tried several types of video...
