Archive
Hello everyone,
I am having a hardware problem. I have an issue with my monitor and the issue is that, my monitor is not displaying the output. In-fact I was using my monitor and all of a sudden my PC was jammed.
I waited for a while, hoping that my PC will run smoothly again, but it didn’t work. For that, I restarted my computer to fix the issue but then my monitor was not working.
To solve this issue, I first of all opened the case of my Central Processing Unit to see whether every thing was working fine or not?...
Read moreHi,
I have taken an assignment on C++ which at first glance looked very simple. Just multiply 2 numbers! The teacher smiled at me. But now I realized why!
The numbers I have to handle are more than 30 digits. So I won’t be able to just use * !
Looks like I am in big trouble. How do I do such big number multiplication in C++.
Read more
Hi there,
I am experiencing a very frustrating issue concerning my Yahoo Messenger program. I have been using this application for many years and I have not encountered an irritating issue as this. The issue I am facing now is that I cannot sign-in to my Yahoo account using the Yahoo Messenger app. Whenever I tried to log into it, the trouble shooting dialogue appears for a few seconds and then disappears.
To handle this issue: First, I tried a totally un-installation and re-installation of Yahoo Messenger. Yet, still I cannot log in. Second, I installed the new version of it, but...
Read more
Hi there,
I am learning coding in C++. I would like to start, by making a full functional calculator. All of them are pretty done but I want some more options which are present in a scientific calculator, like binary calculation. I don't see any function for this. So I guess I have to make one.
I have been trying to add the binary to decimal conversion. I know that the basic process is:
But how do I take the digits 1 at a time. Should I take the binary number as a string...
Read more
Hello Everyone,
I have created a connected graph, where each node represents some fact. The centre is the point of start. You may think of it as a mind map. I want to search the map in a Depth First Manner. I understand the concept but don't know how to apply it. Here is a pseudocode
dfs(vertex v)
visit(v);
for each neighbour w of v
if w is unvisited
dfs(w);
add edge vw to tree T
I am really confused on...
I am doing some analytical program in C++ involving a lot of prime numbers. I don't think checking a number every time, whether it is prime or not would be a good idea.
So I just thought that if I could pre generate all the prime numbers in a list.
But it is taking too much. Time.
vector<int> prmn;
For (int i=2; I<100000; ++i)
If (isprime (I)) {
prmn.push_back(i);
Almost 4-5 second. I hate to find it upto 1000,000.
Is there any better way?
Read moreI have a serious issue that my Task Manager is not working.
Every time I press, alt+ctrl+delete the message appears that, “Task Manager is disabled by Administrator”. Guide me to solve this issue.
I am waiting for the response.
Read moreI'm now frustrated with this problem in Yahoo Messenger Client! I've been using this app for many years and I just met this weird issue. I logged in and the a trouble shooter dialog box appeared for a second only and lost, "how will I know my problem?" :(
I already tried clean uninstalling and installed a new version, but still I can't log in. There's nothing wrong with my account, I can even sign-in to Yahoomail and messenger and it works fine. So I changed my password,...
Read moreHi everyone!
I am having a monitor problem! Actually I was using it and suddenly my computer freeze up, so I tried waiting it for a few minute and hope it will run smoothly but nothing happened.
I restarted it, but then the monitor is not getting a signal then I tried to open the other side of the CPU case and as I see everything works fine. And tried checking the components, fans spin and the HDD is running, it's just that the monitor displays nothing. I tried solving it using other monitors, video cards, unplugged RAM and interchange it,...
Read more
Hay,
I have IBM PC and I am become the victim of damaged power supply. The issue I have with my PC’s power supply is that my power supply is not working. Whereas, when I had turned off my PC last time there was no problem but when I came back I came to know that my PC is not working at all.
To solve this issue I first of all took off the side panel of my PC to see if my motherboard was getting power or not, My PC’s fans are not working and...
