Archive
Hello guys,
I have some problem to built some good Graphics for my website. I want to know which software is the best for Graphics Design? Is it Adobe Photo shop, Illustrator, or what? I want to know is there any easy software to use, if it exists then please tell me. And I have some more things to know where can I find some tutorial to learn how to built good web Graphics.
Its really important for me as I need to built or design some graphics for my own website. To built or Design some quality Graphics I will...
Read moreI recently downloaded a PowerPoint show file from the internet. I want to edit the contents and make my own PowerPoint. How do I do this? When I double click it the PowerPoint show runs without opening it inside Microsoft PowerPoint.
Read moreBefore I left for a trip I turned off my 350 Antec power supply. And when I came back, I hit the power button and there it goes "my computer is dead".
- I took off the side panel to see if my motherboard was getting power, fans are not working and no sounds so I reconnected it and nothing happened except for the green light on the Motherboard.
- I tried wiggling the cord around and unplug it and plug it back in and it still won't turn on.
- I heard some spark or static discharge something when I unplug it and re-plug... Read more
We are currently developing a web application. This application allows the facility for a user, to compare documents side by side. There is a requirement to open the document inside Internet Explorer itself. Is this possible?
Read moreI am struggling to configure SSL in Jboss, on our production server. The production server is running Linux. I generated the CSR and sent it to the certificate issuer. They sent me the SSL certificate. I imported it into the "keystore".
Now what do I do ?
Can anyone help me ?
Read moreI need to call a remote website from my code and get the html data onto a string variable.
How do I do this using Java ?
Read moreI work in an office environment, where all internet traffic is restricted. Most popular websites are also blocked. Is there a possibility of bypassing the restriction imposed on Internet traffic?
Read more
I am having a problem to select a correct Graphics card. I have used NVIDIA 9400 GT series 1GB Graphics card but it has some problem so I want to change my Graphics card.
Now I am thinking about the Brand of the Graphics card which I should select NVIDIA Or ATI Radeon?
I have heard about ATI but never used it. I heard that it has less price than NVIDIA am I right?
What about the quality?
I also heard that the quality is same, am I right?
And can anyone suggest me if I should buy a ATI...
Read moreI am using WordPress to manage my site. I want to use a Google Gauge on my WordPress site.
How do I do this?
Read moreMY PC SPECS:
- Processor: Intel (R) Core (TM) 2 Duo CPU E7500 @ 2.93GHz 2.94 GHz
- Installed (RAM): 1.00GB
- System Type: 64bit Operating System
- OS: Windows 7 Ultimate
I just bought this PC a few weeks ago and the performance is too slow. Last time I've learned that the Windows 7 operating system is made faster than other OS like Windows Vista. Why it is too slow? Even if it is run by a faster processor, which they say that it has faster performance and very responsive in multitasking. I still have 13.4GB free space on my Drive C: and I think it is still enough or more in which a PC performs...
Read more
