Archive
I am using Oracle to learn SQL. Just introductory. I downloaded the Oracle setup file from Oracle's homepage named - "oracleXE 10g". The software installed successfully, but I don't seem to find the user Scott, which was used in the class lecture. I missed the lecture so could not figure out if there was anything said which was not covered in the papers. I asked a partner who said it was a default user. Then why can't I access it? Do I need a configuration or something to be set up at the beginning? Or am I using the...
Read moreI have two servers running Linux. A website is on one and the database with an EJB module on the other. I need to access the remote EJB methods from the web project. How do I get about it?
Read moreI can't start my Windows 98, is has a blue screen and shows NTLDR missing. I try to reboot but unable to do it. In my PC I have very important software in C: drive. What can I do now. If I reinstall this then all of my important software will be lost. Is it possible to repair NTLDR by any way. If any one know, please let me know.
Read moreI have a laptop Acer Aspire 4720z running a Pre installed windows vista, can I replace my windows vista with windows XP? Would there be any problem if i do that in terms of hardware and software, specially the drivers. I don't like to dual boot the system because it use to much hard disk space and I don't want to use any virtual machine. I have tried several times but i had no success. Can I really replace my operating system? I need help please.
Read more
While working on my laptop the screen suddenly turned blue with the error "Windows has been shut down to prevent damage to your computer." I just took this for granted then turned on my laptop again then continue to worked as if nothing happened. But when i experienced the problem again this time i was not able to save lots of my works. How can i prevent this to happen again?
I am using windows 7 on a 32-bit operating system.
I had tried to resolve my problem on my own but same thing happens though i...
When I reformatted my laptop, I made a separate memory; drive (c:) and drive (d:). In Drive (c:), I saved the OS and applications and in Drive (d:), I saved the documents, downloads, movies, photos, etc,. The drive (c:) used to have 55.1 GB of free space but now its only 53.2 GB, though I didn't save any files to drive (c:).
I just notice it whenever I go online. Is there anyone who knows what application I can use? Because every time I surf on the web, it eats up the memory in my hard disk? Where can I...
Read moreI need to design a module in Java for exchanging information between two web applications. I have been researching online on the methods available and came across Web Services, XML, Text and EDI. Looking towards the future, what will be most appropriate?
Read moreLast month I bought a desktop. I have installed Antivirus and I assume and I am very confident that this antivirus that I have installed can help me protect my computer from any harmful elements and viruses that could damaged my computer.
But as the weeks go by I have downloaded different software on my computer,unknowingly it brought some viruses on my computer. I was thinking that I was really protected by the Antivirus that I have installed but unfortunately I was not protected. So I tried searching new Antivirus that could really protect my computer.
Then I do really found...
Read moreHello,
I am trying to write a function that cuts a sentence to its words. And print them back words. I have been doing something like this:
int main()
string s="Hello there how are you?";
string temp="";
vector<string> tokens;
for(int i=0;i<s.size();++i)
if(s[i]!=' ')
temp+=s[i];
else
tokens.push_back(temp);
temp="";
for(int i=tokens.size()-1;i>=0;--i)
cout<<tokens[i]<<endl;
return 0;
Hand coding everything. But the problem is there is always one token missing. I don't get it why? And also please tell me if there is any...
Read more
