Archive
My daughter has acquired my old computer which has been in the family for 8 years. It is a branded IBM computer installed with Windows XP and runs on a Pentium 4 system.
Please help! I am working on my computer to be online for almost a week. You can say I have tried everything on my system and even reinstalling the windows but still the same. I rechecked the drivers and all are properly installed. I am thinking that the NIC port of my computer is shot but the link light on the computer and modem are normal.
Specs:
I am trying new Xfce RC but there are following issues:
One is printer related other is thunar related.
I am using a USB printer which is connected to NAS box but ADD PRINTER not working when i click on it.
So the question is,
Pl tell the way to access printer?
Second, I want to access Network storage drives but NETWORK is not listed in a tuner device list.
So Question are,
Turner does not have similar default function for accessing network devices?
Thunar also not able to add hard drives when i boot it from USB?
But so far I did not look at whether it is problem related to O.S or Directory tool.
Read moreMy computer was infected by a Trojan virus which damaged my explorer. I'm trying to restore my previous settings with the use of my Windows Vista SP2's built-in System Restore. But every time I run it, it gives me the same error message:
Question:
What would you do if this happens after you play some mp3's and other application that needs sound?
VirtualDJ
Error in the sound driver of DirectX
OK
Windows Media Player
Windows Media Player cannot play the file because there is a
problem with your sound device. There may not be a sound
device installed on your computer, it may be in use by another
program, or it may not be functioning properly.
Close ...
Read moreI received a file from a friend with file extension of "XPS". I cannot seem to open it.
What should I do?
Read moreI am setting up a web application on my machine. It uses EJB to access the data in a MySQL database. When I attempt to access the website, I get an EJB exception saying, "could not create a connection". I checked all configuration files but they look alright. Please help me to get to the bottom of this problem.
Read moreI have a Database at my store. Unfortunately, I want to add new column to one of my tables. What I am thinking is to use the command DELETE TABLE and replace it with a new one but I want to save time editing and filling again the data.
Is there a way to just insert a new column which could not affect or change my stored data? Please help. Here is the data in my table.
How to link GPO to a group or User in Server 2008 and how to block inheritance of GPO. If we block Inheritance it will automatically block default GPO Inheritance. So I don't know what to do.
I have tried a lot but failed. Please help me!
Read moreHi,
