Archive
I am using Windows XP. I have a machine that has a hard disk and a CD-ROM drive. I want to make the CD drive as a slave disk and the hard disk as a master. How do I do this?
Read more
I have been entrusted the task of optimizing our company website in order to make it faster. One of my goals is to make the file size of each page small. Are there any pointers or pitfalls I should look for, when attempting to make the size of a web page small?
Read more
Dear all,
I'm using MS Access 2003. I have a large database with lots of information. I can input data in MS Access but I don't know how to make a compiled report. Most importantly, I want to make a report with the exact requirements that I need in my report.
Please let me know if anyone has any instructions which will be most helpful for me. Thanks.
Labu
Read more
DVD has region codes and Blu-Ray disks also have region codes. Are they the same or are they different? I am looking to purchase a laptop. The optical drive configuration can have a DVD or a Blu-Ray drive. I need to make the correct choice here.
Read more
I have been trying to restore my Internet connection for 3 days now and I am getting no where. All my connection would say is, acquiring network address.
I have tried restarting my computer, repairing the network connection and even reinstalling the driver. I tried to look into doing system restore but there is no restore date to choose from.
Any help I can get, will surely appreciate it.
Read more
Dear All,
I'm using iPhone 4G and Apple Macbook pro. I travel lot and always need to be in online. iPhone has a very good screen with a very good resolution but the thing is, you know sometimes I need to view my mail and attachment which is not sufficient in iPhone screen. So, I need to view it in my laptop screen but I can't able to connect my iPhone with my Laptop as a modem. Is there anyone who can help me to give me instruction how can I able to use my iPhone as a modem. Read more
I have an issue that I want to add the folder of “Administrative Tools” on my desktop. Problem is this that, I can only create shortcut of that folder. If you visit the control panel, you will see that there is a folder with name “Administrative Tools”. But if you want to delete the folder, the folder cannot be deleted. It remains the same.
Same as it, I want to create the folder of “Administrative Tools” on my desktop, so that no one can remove the folder. Guide me about how can I add the folder of “Administrative Tools” on...
Read more
I am new to programming with OOP C++. And I have an issue understanding. I need to work on a program with Constructors and destructors. Guide me with the detail concept of Constructors and destructors in classes. Can someone guide me on how to do this with OOP C++?
Read more
How can we access the array elements? I am working on loops but there is a problem in the code, every time I have to initialize “I” to the next value when I want to store any value in the array. Is it right way to assign values to an array? Int marks[5]; Int i=1; Marks[i]=5; i=2; Marks[i]=4; If yes then tell me how can I access the values from the array when I want to display the value of specific index?
Read more
I was trying to find out what version (build) I have of Windows 7. I need a certain update and the build will tell me if I have it.
Thanks!
Read more
