Archive
I happen to be learning HTML coding for basis web design. I know how to implement the html codes but poor at CSS especially linking it to html. I have a simple web page and a separate style sheet I want to link it to. Someone to help me.
Read moreI want to repair the Norton which is installed in my system, but I cannot remove it from the control panel. What can I do? Please help me!
Read more
I have a serious problem. I want to remove bloodhound w32 from my PC.
It gives me more problem to remove this.
Can someone help me?
Read morei am trying to cancel an auto ship program involving a product. when i try to contact them at the email address i was given, i get this. "could not perform this operation because the default mail client is not properly installed. what does it mean? what do i do to correct it?
Read moreI keep getting notices that I need JAVA to see certain webpages including my online banking and some games. Where can I get MS JAVA plug-in?
Read moreI keep seeing the same list of windows XP updates appear even after I have downloaded and install of them. Sometimes windows updates just hangs. Is there anything I can try?
Read moreHello,
I have one question and I will be very grateful if you help me.
I am hesitating between two video controllers:
ATi HD3650, 1GB PowerColor, AGP8x, DDR2, 128bit, DVI, TV Out
ATi HD4670, 1GB PowerColor, AGP8x, DDR3, 128bit, DVI,
My video slot is AGB x8 on Asus K8V-X SE Motherboard. So my question is can my Motherboard use DDR3 memory?
Read morewhen i run disk clean up, it gets to the first three bars when checking the files(status bar says "compress old files") and then just hang there? if i close it down and run it up again, then it just never comes up at all.
Read moreHi,
I have a problem where my taskbar disappeared and there is no start button. This happened after windows explorer opened an unresponsive folder.
I know that this will be corrected if I restart the computer but there is another way to get the task bar without restarting the computer?
At times there are still applications that I am working on and I lost my work when I restart the computer. All the best!
Read moreHi,
Please help me how to make my internet connection faster? I am using a plug-in broadband.
regards, karen
Read more
