Archive
How do we avoid lockups, blue screen and frozen screen? I have once experienced the 'blue screen of death' on my laptop before and it was running on Windows XP. How can I prevent this from happening again?
Read moreI want to upgrade my old Microsoft Windows 98 operating system to Windows Vista.
I have enough disk space to install Vista, but I also need 800 megahertz to run Vista on my computer.
Is there a way to increase my Megahertz so I can run Vista?
Read moreI have installed Ubuntu 9.04 with Wubi inside Windows XP (like regular app) and when I start my PC there is a option menu which is asking what I want to use - Windows XP or Ubuntu. The thing is that I reinstall Ubuntu OS (its just not for me), but the option menu at start up is still there.
The PC is working fine, but its just annoying. What can I do?
Should I reinstall Windows OS?
Read moreMy computer is working slowly so can anyone tell me how I can fix the problem?
Read more
Hi all,
What is macro used for in Excel?
Any insight is useful.
Could be a basic question but for me it's like a mountain.
Thank you
Read moreI am using windows XP OS.
How can I find MAC address and IP address of my computer.
Please guide me on this.
Read moreI want to insert no's into a txt file. I periodically get a lot of text files from a software which needs numbering. I want a script that can insert no's in from of each word in every line. Can anyone help me with a script to do it. Preferably a batch script.
Read moreI want help to find the OS serial no on my vista and few windows XP machines can anyone help me to find this.
Free tools or scripts
Read moreCan anyone help me with a PowerShell script that I can use to retrieve a specific storage mailbox names and sizes into a text file or CSV. Would be helpful if i can get the sizes in MB.
Surendar
Read moreWhat is a VPN and are there any suggestions you can give to select the best.
I am looking for a solution to connect from home for my employees.
We have 30 employees and 20 of them need to connect.
Read more
