Archive
Problem with my task manager does not open at all.
Is there any solution or options I could check?
I have windows XP and SP3 and this has happened just all of a sudden and cannot kill any processes either.
Read moreExcel macro or script that can make all data into caps in a excel sheet Some easy way which I can use to make all words CAPS.
Help with a easy way to retrieve all computers in the Domain With Operating system details.
I would need a way query which can be used to retrieve information of all machines with OS and SP if possible.
Thanks in Advance
Read moreHi Experts,
How can i remove a single space from the front of each cell in a Column.
I want a formula that i can use to remove one empty space in front of each words or words in the cell.
I have data as below
| Hand OK |
| Techyv |
| Com |
You can see in the above table the start is a space. need to remove it
Thanks in advance
Srene
Read moreSimple excel question. How can i convert a row of data into column
I have an excel in Row 1 i have 100+ cells of data.
I want to get them into a Column
Can anyone help me with a script or a inbuilt way to achieve this.
Read more
Hi All,
Test prints to be given to all printers in the building each day as a printer check for quality and if any issues.
I want some script that can run as a scheduled task and give a test print to all printers which team members in charge of the floor will just have to go to the printers and check.
This would be a very useful help if automated.
Rahman
Read moreAny script that we can use to replicate between Dc's.
I want to force replicate Can anyone help me with a script preferably Powershell or VBS.
NT workstation machine not able to add to domain.
Is there a known issue or a solution anyone knows how to add a desktop to the Domain?
My domain is Windows 2003.
I just have one desktop that needs to be in this OS for a few months and have had no luck adding it to the domain.
Read moreInternet usage meter. does anyone know of a software that can show us the stats on our usage
I have BSNL and Airtel used in my home and office. I want a software free or small price that can record our usage and warn us when we exceed usage.
Is there any software out there or any trick to record this and take precautions before we exceed the limits.
Read moreI have windows 2003 ad setup in my office and do regular checks on disabled users and some other general checks by using the search filter methods .
