Archive
My computer runs with Windows XP SP2 and the RAM size is 2GB. The motherboard is Foxconn G31.
Every time I am trying to open Windows Media Player an error message pops up. ‘The File wmp.dll has , problems’. Also I am not able to install Media Player 9 because of the error ‘Latest version is already installed’ and got quit.
Please help me to fix the problem.
Thanks in advance.
Read more
When I am booting up my system and Fatal Error message is coming with the number of C000021. After that it shows a blue screen. It is not able to start in safe mode with command prompt, or networking. After that it shows me Trojan.bamital.inf in the system and it is not able to remove. The explorer.exe is just disappeared and I think it is because of Trojan. Please help me to fix the problem.
I will thankful for all help and support.
Read moreWhen I was attempting to connect by using SMTP port 25 to Rodrunner with MS Outlook 2010 beta, an error message comes up. The settings are same in all other systems which are runs with Outlook 2003 or Outlook 2007, so it was not problem with the settings. I am getting the following error message when tried to send mail. ‘No authentication methods are supported by this client in the server’.
Please help me to solve this issue.
Thanks in advance.
Read moreHi brothers,
I am having some problem with the WMA files.
Those files are not able to play in the new Media Player.
I want to download the license for the same.
But when I am trying to download the license an error comes up with the code 438.
Please help me to solve the problem.
Thanks in advance.
Read moreHi All,
My windows Media Player was working properly. But recently it gives errors. ‘Win Media Player cannot able to support this file.’ I don’t know that is to be done. Please help me to solve this problem. I will thankful for all help and support.
Thanks in advance.
Read moreHi techyv Experts,
I am looking help to fix the Error Code – 10 using Exchange 2007 with the Outlook 2007. The error message is ‘Problem with the server’s security certificate. Security certificate name is invalid. So, Outlook cannot connect to proxy server. Please provide me step by step guidance to solve the problem.
Read moreHi Experts,
When I am trying to do any installation or update an error message comes up. ‘The win installer service is not able to access. This is happening due to the installer is not properly installed.’ I am using Windows 2003. Please help me to solve this problem.
Thanks in advance.
Read more
I have bought a new system with the configuration of 2.5 G, Gforce 4, 512 RAM, OS is Windows XP and regularly paying the game ‘Antz’ DVD in Windows Media Player. But recently I am not able to play the game. After inserting the DVD, an error comes up. ‘Media Line is not able to play’ and shows some numbers.
I have confirmed the Windows Player is set p to read DVD. I have also searched in websites with the error code, but nothing found. Please give me a solution to fix the problem.
Thanks in advance.
Read more
Some times when I am selecting with the ‘Browse for folder’ an error message comes up with ‘Disk not found’. Usually when downloading and selecting the folder through the ‘Browse for Folder’, this is coming.
Please help me to find out the problem. I will thankful for all help and support.
Read moreEvery time I login to the computer an error message pops up.
The error message displays that ‘The installation of Windows Media Player is not properly done.
So it is to be re-installed.
You can install the same for MS website.’ It contains the ‘No’, Yes’ and ‘Close’ options.
This problem started after the installation of Windows Media Player.
I have re-installed the application from their website, but there was no change in the error message.
I am using windows XP Pro SP 2 and McAfee anti virus. Please help me to fix the problem.
Read more
