Archive
Hi Bothers,
Failure in Setting Data for ‘Top’ Error
 When I am log in as a user I am getting the above error message sometimes. But if I am log in as administrator there is no problem. I have to select end task from task manager to exit from the application. Please help me to sort out the problem. Thanks in advance.
Read more
Hi all,
I have downloaded and installed ‘Photoscape’. The Coral Photo Pro was already installed by me.
But when I am clicking on the shortcut it gives an error message which says that ‘Failed to initialize’.
I have done this with my new computer which runs with Windows Vista.
Please help me to find out the problem.
Thanks in advance.
Read more
Error in copy Files To – The relative name contains only space or empty.
When I am trying to create a Zip file with a Web Service by using Java.util.zip application, an exception error message comes up. The Zip file is not as complicated as it contains only text files and a folder contains some images. It can be accessed with WinZip application. The error message details as follows:
Type : System – Argument Exception
Error : The relative name contains space or empty.
Source : Exceed – File system
I am using the Windows 7 as OS.
Read more
Hi Experts,
I am getting an message which displays that ‘Teamviewer is executing with this website.’ I don’t know what is the meaning of it? Please guide me to find the problem.
Thanks in advance.
Read more
I have downloaded a good cursor from CursorFX.
It was working properly. But recently it is just disappeared and it shows the Windows default mouse pointer. It is only showing ‘Create Short Cut’ in the Control Panel > Programs section, so I am not able to uninstall and re-install the same.
When I am trying to open the CursorFX it shows me an error message. ‘It is not having an application associated with this as it is not able to perform the action. Kindly, install the application of if it is already installed please associate in Control Panel.’ I don’t know...
Read more
Hi All,
Even after the re-installation of DeepBurner I’m getting an error message which says that ‘ASPI Initialization Error’. I have also tried by unchecking the ASOI driver box in Setting under Reorder, but there was no change in the result. There is also a problem with the image burner. It also give me an error message. ‘Error occurred while accessing 2 drivers. Drives are no seeing into the application or it is not able to detect any drives’.
Thanks in advance.
Read more
When I am attempting to update the webcam drivers, an error message pope up which displays that ‘A network error happened when it is trying to read from the file ‘LWS32.msi’ in the Installer folder under Windows folder. Error code is 1316.’ I am not having the setup disk.
Please guide me to fix the issue.
in advance thanks.
Read more
I am burning movies from the hard disk to a freecom device by using the Deepburner free package and the version is 1.9.0.228. it was working properly for more than six months.
But suddenly I’m getting an error message which displays that ‘Drive may be busy, not ready or empty’. After that I am using Verbatim DVD-R disks and the basic burnings are doing properly. I thought it is the problem with the hard disk and changed the hard disk. But the error still comes up.
I have also tried by changing the writing speed to very low, but there was...
Read more
I am using Dell Inspiron 1720 which runs with Windows 7 and the browser is Firefox. When I am trying to add LaCie Genie Timeline external drive an error message just comes up. ‘Warning! Back up is not configured. It is not able to access the backup settings. It is to be set up a new back up’. After the message, I have to start a new back up. It is happening most of the times.
Please help me to solve the problem.
Thanks in advance.
Read more
When I am trying to connect the web camera to computer and error message is pops up.
‘It is not able to make video capture filter’. The error code is 8007045a.  I have also tried by installing the AMCap.
But it is also giving an error message. ‘It is not able to add video capture to the filter graph.’ DLL initialization routine failed.’ I have no idea whether the webcam or Windows is having problem.
Please guide me.
Thanks in advance.
Read more
