Archive
I have a Nuvi 1450, and I tried the loading custom POI software in it. It has been working fine for several times now until I get the following error when I try to load the software. I have attached the screenshot below.
I don’t have any idea what changed and why is it happening.
I would gladly appreciate your help towards my problem.
POILoader
There is a problem with this GARMIN application
Please press the button below to copy the log file to the clipboard, then paste it into an e-mail. send the e-mail to GARMIN technical Support at...
Read moreI have a Mac PC with OS X v10.6.2. I tried to update it to the latest version which is 10.6.3, and suddenly, I received this error message during the installation stating that “System extension cannot be used” but the update was successful.
I have attached the said error below.
I don’t know what could be wrong with it.
I wish you could help me out with my problem.
the system extension '/System/Library/Extensions/CDSDAudioCaptureSupport.kext" was installed improperly and cannot be used. Please try reinstalling it, or contact the product's vendor for an update.
Read moreLast night, I started getting the attached error message and I have been stepping through this VBA event subroutine. I already encountered this problem before and I fixed it just by deleting the subroutine script after copying it to a text editor; however, this time I cannot fix it by myself.
It shows that there was no Event Procedure so I tried to do other procedure but nothing happened. I already did some research involving Access Option >> Current Database >> Name Autocorrect Options >> Perform Autocorrect but still no improvement to my problem at all. This problem makes me...
Read moreI currently have two PC’s, a laptop and a desktop PC. Both are on a BT networking and have the same software which is McAfee 3-User Software. My problem is with the old desktop, there seems to be no problem with MVT on my Laptop.
I had to Re-install McAfee some time ago, and it had no problems. On the second attempt, I have failed to download MVT on my desktop. I have attached the error message below so kindly please send me some resolution to this.
Thank you in advance.
Windows Installer
The path 'C:Documents and SettingsuserLocal SettingsTemporary...
Read moreI am a new user of Mac and RapidWeaver. I have to stop working with my Windows/Flash Based websites and rewrite them due to inaccessibility to iPhone and iPad. I have already been through the checklist, I deleted the cache, and I am still stuck with the attached error below stating that
FTP Publishing Error. I have done everything that I could possibly do, but I still get the same message. I am not so familiar with RapidWeaver and Stacks. And as much as I would like to be more knowledgeable about it, I could not continue unless this error...
Read moreI just had my new Business Analyst MXD software and after installing it, an error message appears stating that “No valid source could be found for product ArcGIS 9.3.1 Business Analyst. The Windows installer cannot continue.”
I was just curious because I just purchased it and have done nothing but install it. I have attached the screenshot of the said error so you guys could easily identify it and help me resolve my problem.
Error 1706 No valid source could be found for product ArcGIS 9.3.1 business Analyst. The Windows installer cannot continue.
Read moreI’ve been using AutoCAD MEP 2010 for about a month now and aside of having common errors such as “running out of memory” and some occasional unique errors; everything seemed to be fine until now. When I tried to use it once again, I suddenly received an error stating that “Unhandled exception has occurred in a component in your application.” Two of my PC’s are having the same error. I have already tried everything I can to resolve this problem such as Repair and Re-installing but I still get the same error message. Can someone please help me?
I’m having problems with my LG PC Suite IV Software. I was trying to synchronize the contacts between my mobile phone and my PC using this software but when I try to start syncing, I suddenly received an error message stating that “LGUX.exe has encountered a problem and needs to close. ”
I have attached the screenshot of the said error for you to easily familiarize my problem. I am very much looking forward on helping me resolve my problem.
LGUX.exe
AppName lgux.exe Appver: 1.0.0.1 Modname:...
Read moreI have an HP iPAQ Pocket PC h2200 series.
While I was trying to update the ROM, I suddenly received this error message stating
ERROR 100. This error appears when trying to change the language from Spanish to English and made me decided to update my Pocket PC to make this work. I have attached a screenshot of the said error message below.
I would greatly appreciate your help on resolving my problem.
ERROR 100: INCOMPATIBLE IMAGE
The ROM image that you are trying to use is not designed to work with your iPAQ Pocket PC.
These are the characteristics of...
Read moreThis error occurred when I tried to check my mail in Outlook Express. The error is stating:
“Error found in Custom UI XML of McAfee AddIn; Line: 1, Column: 118, Error Code 0x80004005, Unknown Namespace: //schemas.microsoft.com/office/2009/07/customui, Element: Custom UI. ”
And another error message appears when I hit the OK button on the first error message:
“Error found in Custom UI XML of McAfee AddIn, Line 106, Column: 11, Error Code: 0x80004005, The node is neither valid nor invalid because no DTD/schema declaration was found. ”
After these two error messages, I was able to check my mails. I also found another error...
Read more
