Archive
Please see the error message. ‘An error happened when the initialization of the application. It may be due to some application security problem. Please allow the communication in the system’. This error message is coming when I am trying to disabling antivirus software. Please help me to fix the problem.
I will thankful for all help and support.
Read more
I have a JavaServer Faces (JSF) Application and I been trying to run it through Tomcat 6.0 with Eclipse Europa IDEbut I keep getting an error message in JAVA that says, “java.lang.NoClassDefFoundError: javax/faces/event/SystemEventListener”. I also have JSF-API 2.0 and jsf-impl.jar. What should I do to resolve this?
Read more
Hello. I upgraded my Windows Media Player 9 to WMP 10.
I used this as my default media player. It’s been working well since I upgraded it to version 10.
But lately, when I try to play an .mp3 file, I double-clicked the file on my saved media folder to automatically play it on WMP.
But nothing appears on screen. The song did not even play its sound. But I got an error message with Error code C00D109B.
I don’t really know what this error is all about as much as I also don’t have any idea on how to fix it.
Can someone...
Read more
I am using Zune for syncing my media files. Recently, I downloaded few songs on the marketplace and I got a codec error C00D109B (C00D0BC2) . What is this error all about and how can I fix it?
Read more
I need help on playing Yahoo LAUNCHcast Radio on my Windows 7 PC. I’ve been using this for few almost a month without having any issues. I even reformatted my computer system due to other issues but the error on my LAUNCHcast is still persisting. I cannot make it work even if I already downloaded all the updates needed. What can I do to make my LAUNCHcast work again as it was before?
Read more
I am trying to set up iPhone with iOS through Apple MDM capabilities with the use of the iPhone Configuration Utility. I want to make a configuration profile. Doing this, I cannot set up the Identity entry which gives me an error stating: “Add credentials in the credentials payload.” iPhone Configuration Utility Documentation said, select the certificate that the device uses to identify itself to the MDM server. Add the certificate to the device using the Credentials Settings, or use SCEP Settings to provide instructions for the device to obtain the certificate using SCEP. In the first place, I...
Read more
I need to install Sage Peachtree Accounting Software but I am getting an error message that says: "Error 1935. An error occurred during the installation of assembly
'Microsoft.VC80.MFCLOC',publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50727.762", processorArchitecture="x86"."
How can I resolve it?
Read more
Hello. We have an OKI C9600 Colour Laser Printer in our office. But we moved to a new office so the printer has to be set up again. But we cannot make it work as we are having an OKI C9600 097: Fatal Error.  I tried everything but it still doesn’t work. How can I fix it?
Read more
I am getting an error: “perl.exe has stopped working” when I attempt to modify mySQL 3 tar source code.
I tried to organize and compile the perl-5.14.1 installation from mingw32_nt-6.1.
This runs on Windows 7 without errors.
How can I fix this error on perl?
Can I send an attachment with image file that is 400KB in size? Help please.
Read more
I am running Windows Vista Ultimate and IIS 7 when a web page just stopped on responding and after reloading the page an error message appears in EventLog(System) stating: Cannot bind SMTP requests to port 25 because it is already in use by another process.” What is this error and what is the resolution for this? Kindly please help me.
Read more
