Archive
I have Exchange Server which I usually use my Outlook 2007 in it. My MS Outlook is not responding. It hangs for like 2 minutes and then it responds again and it hangs again after 5 to 6 minutes. It is irritating me.
It also hangs even though it is minimized. If I wanted to restore it from being minimized, it cannot be restored within a minute. If I write a message, it hangs again. The cursor is gone preventing me from typing further and comes back once again.
A text saying offlb.exe appears when Outlook hangs. Is it an error...
Read moreMy HP computer has Windows Server 2003. I have configured everything into RAID Level 5 and 3X148GB SCSI Drives. It has 2 partitions such as, C: System and D: Data. My Server 2003 is a multi-server. It has one domain but serves two sites and it replicates AD with APN. My drive C always dismounts my database and has very low disk space. I was thinking that maybe I need to clear out some unnecessary files but after doing so, it still cannot get enough space. The system prompt asked me to reinstall a new SCSI Drive and make...
Read more
I wanted to move my server to something that runs Presentation Server 4.5 64-Bit using CHFARM.
I already have Oracle Data Store. While trying to set up Oracle connection, I got this error message saying, “Database connection cancelled or failed.” What should I do?
The image is shown below together with what I tried to do and the error occurred while trying to do it.
Thanks!
DB Error
OK
Hi, I got this error when I tried to install Presentation Server 4.5 64-Bit with Oracle Data Store.
In the midst of the installation process, this error message appeared: “Error 26005.
Could not start IMA service in CTX_IMA_ StartIMAService State = 1.
Clicking OK didn’t help at all. So I am asking our Experts here to kindly please send some help.
Thank you.
Installer Information
Error 26005. Could not start IMA Services in CTX_IMA_StartIMADService State = 1
Read more
Hi everyone,
When I try to open QuickBooks files from my server I got error message. This is error that I am having first time and I don’t know what to do. How can this be fixed? OS Windows 7,
Thank you
Sean
Warning
An error occurred when Quickbooks tried to access the company file. Please try again. If the problem persists, contact Intuit Technical Support and provide them with the following error codes: (.6000,.80).
I cannot use Nero in burning my music files. An error message from Nero CD-DVD Speed saying, “Error: Invalid field in CDB. My operating System is Windows 7. I don’t know how to fix this. It still keeps on coming out after clicking OK. How do I stop this from appearing and reappearing? Any suggestion is highly appreciated. Thank you in advance.
Nero CD-DVD Speed
Error
INVALID FIELD IN CDB
I wanted to burn files to a DVD disk using Samsung WriteMaster SH-W162Z and Nero. Lately, I got this error saying, "Burn process failed at 16X (2,400 KB/S)". This error message appeared when files are about to be completely burned. So my disk becomes unusable. I tried it again but the same thing happened.
I broke another disk again. I cleaned my DVD ROM and checked whether the disk is inserted properly or damaged. Then I tried burning files again but same error came out. How do I fix this? I have wasted four disks already. Please help me. Do...
Read moreHi everyone,
On my computer I’ve installed Windows 7 64 bit, QuickBooks 2007.
Now I am having problem whenever I want to print invoices that are saved as PDF in QuickBooks.
This issue I didn’t have when I had installed windows Vista 64bit.
Could this be because of OS?
Everything else works great. Any suggestion is more than welcome.
Thank you
Ivory
Intuit Printer Library
Could not print to printer.
Check your printer selection.
Printing may have been cancelled from another program.
Read moreI am encountering a fault with my Nero info. It says, "Unable to make an XML parser example. Please reinstall XML core services (MSXML) 4.0 SP2 or higher."
This error occurred when streaming either Nero or Nero Nonfat. I went to find any online has improved but I could not deed any. I am proven uninstalling and reinstalling Nero but I get the one misconception.
Anybody got the corresponding job? Please refrain.
Read moreDear all,
This problem I don’t know how to fix and I really need help. This situation is similar even if I want to save PDF or any other format and even if I want to send invoice I got the same error message. On my computer OS is Windows Vista. Please help
Noreen
Warning
C:tempSI22.pdf could not be created due to error#-121
Read more
