Archive
Hi everyone,
I wanted to mount my mirror on my new system. Please help me how to do it. Here is some information I need to share with you so that you could help me do it. The Disk A has an OS failed.
It requires a replacement and reinstallation of Windows Server 2003 R2. The disks B and C are mirrored on the field machine. What I wanted to do is mount my mirrored disks B and C on my new system. How do I do that?
Read more
I am having problem with Samsung spinpoint F1 HD. Mac Pro 2.8 GHz Quad Core Leopold. When I booth error message appears. I am not shore what should I do with it. On it I don’t have too much files. Suggestions, ideas are more than welcome
Thanks
Sarah
Disk Repair
The disk “Samsung F1 HD” was not repairable by this computer. It is being made available to you with limited functionality. You must back up your data and reformat the disk as soon as possible.
Read more
Hi, I am working in this program called Industry Propriety in my office. Someone who already left our office had programmed our software to make it restart with 5 minutes interval. Now my task is to change the interval because five minutes is too fast. As a technical support person, everyone is expecting from me. I was working hard finding ways on how to terminate the current process setting and adjust it to their preferred time interval. Please help me find software that can do it for me. My server is Windows 2003.
Read more
Hi everyone,
Recently I got NGX R62. OS Windows XP SP2. I wanted to update SmartDefense and I got all update files. When I wanted to run update I got error message. Any suggestions?
Please help.
Thank you.
Samantha
SmartDefense-Failed to update Smart Defense and Web Intelligence
Check Point SmartDashboard
Failed to update Smart Defense and Web Intelligence.
Data was not found.
Read more
I wanted to upgrade my Server 2003 to Server 2008. But I don’t know exactly how to do it. My server 2003 has sub-domains and has 180 AD users. Please send me some valuable instructions on how to migrate to Server 2008 without touching my stored data.
And also, I do not want to remove my AD setup and file locations because I do not want to do set it up again. Is there a safe way to do this? Please advice. Thanks!
Read more
This error I got recently and I don’t know how to fix it. On my system I have Windows XP. I wanted to install Snarfer. During installation I got error message and freeze everything. If anyone knows anything about this situation please help.
Thank you in advance
Sharlot
A Runtime Error has occurred.
Do you wish to Debug?
Line: 5
Error: Unspecified error.
Read more
Hello, I have just successfully installed Windows 8 in my VirtualBox. The installation process was smooth and quick. I was so eager to use it but when I get into it there were no available feature except the control panel and the desktop. And it moves me to the old or the original host system. So I just tried clicking on whatever I have seen on the desktop but none of the applications load. Please help me with this. Do I need to reinstall the software?
Read more
Hi everyone,
I really need some help with this. On my system I have Windows 7 32 bit, and I wanted to install MS Office 2010.
Already I have installed MS Office 2007. Easily I have uninstalled MS office 2007.
My friend gave me installation CD MS Office 2010. During installation error message appears and I had to exit.
I got other copy of installing CD, but the same happened. Please help
Thank you
Edward
Setup Errors
This product installation has been corrupted. Run setup again from the CD, DVD, or other original installation source.
Read more
My operating system is Windows 7 with 4GB RAM, Quad-Core, 1.7GHz processor capable of running Windows 8. But I am wondering why I cannot run Windows 8 32-Bit in my VirtualBox. When I tried running it, it just loads and stops at the preview saying, “Windows Developer Preview.” After that, it just disappeared and the computer says it needs to restart. So I just restarted my computer system and once again tried my luck but I got a similar message plus another message telling me that it meant to work in 32-Bit color but it has been reduced to 24-Bit. I could not think...
Read more
Hi everyone,
I have done some upgrades to components on my system and reinstalling Windows XP with SP2.
Also,we had to make some software updates to the server so it can support more connections.
Recently error message appears. Now I am confused, because I thought that we had made all right updates (SQL Server 2005 all available updates are installed) so that we don’t have to buy new server..
Any suggestions?
Thank you
Brad
Non-Fatal Error
Retrieving the list of recent order summaries failed. (mscorlib)
Additional information:
DoaProxy :unable to intercept  method name ‘FindAllSummaries’, cause : A transport- level error has...
Read more
