Archive
I usually take out the battery of my computer whenever I am plugging it in the socket in order to save my battery’s energy. My computer automatically installs Windows update every time I shut it down. It says do not unplug your computer and it will just shut down when the installation is complete. I know it would take some time. But accidentally, the computer cable was unplug or might have just loosen plug connection and my computer quickly turned off. At first I thought it was just alright. But when I started it again, I got an error...
Read more
I am running Windows XP on my Dell Dimensions 5150 desktop PC. When I am performing a reboot, I clicked F11 so that I could perform the PC Restore. I got an error message saying that the:
“Restore was unsuccessful. Please click restart to reboot.”
Now I just did what it said. I rebooted my PC but my files are inaccessible. Then it gave me a second error message:
Loading PBR for descriptor 2… done. A disk read error occurred. Press Ctrl+Alt+Del to restart.
I am now so tired of doing everything again like rebooting, restarting and all. And I just ended up...
Read more
Hi everyone,
For business I started using Skype. On Internet I have read about recording videos and sounds from Skype can be done with Evaer video recorder. My friend has downloaded it for me. The main problem was during installation. I got error message and even I had option retry and Ignore I had to abort operation.
Any solution or suggestion is more that welcome.
Thanks
Ethan
Evaer Video Recorder for Skype 1.1.1.26 Setup
Error opening file for writing:
C:Program FilesEvaervideochannel.dll
Click Abort to stop the installation,
Retry to try again, or
Ignore to skip this file.
Abort
Retry
Ignore
Read more
My TeamViewer 6 gets error whenever it is initialized. The error message is shown below as image. The error is telling me about the security blocking network communication so I tried to change my Windows Firewall setting by fully blocking everything with the exception of the TeamViewer. My Avast! Antivirus is permanently disabled first while adding the TeamViewer as the exception again. I have tried reinstalling TeamViewer too, it replaced my old TeamViewer version 5 first and then I re-installed version 6 again. I boot my computer once again to make sure everything went refreshed. But unluckily I still...
Read more
On my new HDD I have Windows XP Home 32bit.
Now I have available updates, service pack and one of the files that I had available was Windows media component Setup application.
When I run installation wmfdist11.exe I got an error message.
Any help please?
Thanks
Jayden
WMFDist11 Setup Error
Setup has detected that the version of the Service Pack.
Installed on your system is lower than what is necessary to apply this hotfix.
At minimum, you must have Service Pack 2 installed.
OK
Read more
While downloading Malwarebytes, I got an error message saying: “Program error load resource: (0.53) report this error code to our support team. ” I just clicked the OK button because it did not further tell me on how to submit the error to their support team, and it finished the installation successfully.
But I got the same error message when I tried to run my newly installed antivirus. I downloaded and installed the free version of Malwarebytes with my Windows XP computer. And also, I am using Mozilla Firefox when downloading Malwarebytes in my Dell 3000 laptop. Please help me...
Read more
This is first error that I had on my computer. On my system I have Windows Vista 64bit.  As a movie fan I collect movies.
For the compression I have installed  VirtualDub and AutoGK (automatic installation without any modifications).
Now when I run video compression error message pop up.
Please help, I never had this error message.
Thank you
Jacob
VirtaulDub Error
Output compressor error: The source image format is not acceptable. (error code -2)
OK
Read more
I need help on converting my video files. I want Xilisoft Video Converter to convert some .VOB files to HD files like H.264 and DivX HD. It will just start converting then it will take so long with the process and then hangs. It happens every time I am attempting to convert my videos.
I need some advices on how to make this work. It worked fine with .VOB files but it does not allow it to connect to different video files as it started to hang upon trying to.
Thanks in advance.
I will anticipate all incoming suggestions from you.
It would...
Read more
Hi
Recently I started playing game “Call of duty 2”. Because I wanted to enjoy playing game I’ve bought it. OS Windows XP. During the game I got error message. I am not shore did I get error because of a game or because of something else? Did anyone had similar problem? Any suggestion?
Thank you
Michael
Error
Component “mss32.dll” or one of its dependencies not correctly registered a file is missing or invalid.
OK
Help
Read more
An error message is constantly showing up saying: “Error 1316 and Cannot access JAVA JARLIB JAR. Unable to access Jar file LIB/MP3 rocket.jar." I had successfully installed my MP3 Rocket software but I couldn’t open it. I tried seeking online help but I get no response yet. I also have tried sending inquiries to JAVA online but still no reply.
Please help me I’m getting so paranoid now. I wanted to get to MP3 forum but I could not log into it because it does not open. Any suggestion is highly appreciated. I would be very glad to have immediate...
Read more
