Archive
I got this error message for a couple of times.
Also,I try to fix this issue with VMware support but it couldn’t help me with this. My back up with VMware ESXi and everything was fine.
When an error message appears for the first time, my reaction was disable CBT on VM and commenting CBT lines in the vmx. But this didn’t solve my problem. I still got this error message.
Please help to solve this problem. Any suggestion is more than welcome.
My best
Emma
Power On virtual machine
Reason: Invalid signature in change tracking file.
See the error stack for details...
Read more
I am using Windows Vista as my Operating System. I have made a very good edit in my system especially in the calendar and the task features. Now when I tried to view my scheduled tasks, an error appeared on the screen saying: “The task image is corrupt or has been tampered with wavepadShakeIcon”. I know this is something that is very much connected to my scheduled task which is the NCH Swift Sound. When I edit this task, will it affect Wavepad? I am using a genuine Wavepad Version 4.52. Please advice. Thanks.
Read more
I need help with AVG Anti Virus Free Edition 2012. After turning on my computer, I clicked “Install updates for Windows” then I get an error message from AVG saying: “An unspecified error occurred in AVG. Would you like to send diagnostic data to AVG technical support department for further analysis?” Is AVG 2012 trusted? Or should I not install any Windows update at all? Which one must be the cause?
Read more
Hi there,
I am having problem with opening some folders/ applications.
First I had a problem with opening files from my external drive (that are back up files). All files aren’t infected or anything.
Now I have a problem when I want to open some files/application on HDD.
On my system I am running Windows Vista Home 64bit. Is there any solution for this problem?
Thank you
Chlorine
Location is not available
C:UsersrgangulyApplication Data is not accessible.
Access in denied.
OK
Read more
Hello there.
I just wanted to delete numerous files after re-installing Wuala online storage.
I saw the files were being deleted. Now I wanted to empty my recycle bin but I simply cannot.
An error message popped up saying: “Delete from trash failed.
Reason: item [XXXXXX, XXXXXX, XX] does not fulfill the preconditions of this transaction.”
I saw the deleted files were moved to some backup files and were not deleted at all.
It is so confusing.
Please I need suggestions.
Read more
How do I play Blu-Ray disk with Power DVD 9 Ultra? I have just bought my Power DVD 9 Ultra but I was so disappointed because I could not play any Blu-Ray music with it and I am getting an error message with code 0024. The online help is not very useful.
I am just redirected to some forums which I don’t see any help at all. I need somebody to respond to me immediately. I have tried re-installing the application set up but still, it did not work. Do I need to discard this and buy a new one?
Help...
Read more
I have a Windows 7 64-Bit as my Operating System and I have just installed Daemon Tools Lite 4.45.1.0236 Free License in my computer. After it completed the installation process, I could not find the file at all. It is not in the system tray and I could not find it anywhere. How could I find it where? It’s so erratic that the file is missing just right after it is being installed. I already have tried re-installing it for so many times but I still could not locate where the file goes. Could you help me?
Read more
I got a medium risk error with Clone CD. It also said that the Clone CD is not compatible with the CD writer. When I started to write file on a CD, it worked fine at first. Then after writing several files, this “Medium Risk Error” popped up and writing did not even finish. I’ve tried it using four different CD’s already but all is just wasted. Then when the incompatibility error appears, the computer needs to be restarted before the CD is accepted by the Clone CD. I’m so confused now. Please help me how to fix this.
Read more
I have been using Symantec Ghost 11.5 in making and creating images for my desktop PCs and laptops. Recently, I got this error message saying that the application just stopped when system restore is done. I am stuck with the Disk 4. I need to continue it manually and have to select disk 5 so that it will continue working. I also noticed that image errors occur only with desktops and works fine with laptops. I am using it with Dell and HP laptops and it went well in a normal way. Should there be a way of resolving...
Read more
I got a problem using Todo Backup as my backup for my new virtual PC. I tried converting some JPEG files to VHD and at the same time I wanted to use it as my HDD and boot my virtual PC from there. But I am getting an error saying: “A disk read error occurred. Press Ctrl+Alt+Del to restart." I got messed up now I do not know what to do with this error. Please help me with this. I really wanted to shift from my real PC to my virtual PC but this message has kept me from...
Read more
