Archive
I need to fix this error with Everest Home Edition. It is saying that the driver is not digitally signed. I am using Windows Vista Business Edition 64-Bit on my HP 6715B computer. Doesn’t Windows Vista accept non-digitally signed drivers? But I think it usually does. Maybe something is wrong with how I installed it. I need logical suggestions please. Because other online help just doesn’t make sense at all. Thanks a lot.
Read moreHello everyone. I got this error message: “C:Program FilesEraserEraser.exe” addtask –dir “C:UsersdunDesktope” –s manually –r. The dir is identified as the directory to erase. This error occurred when using the eraser on the command line. I’ve tried it both with the directory and the file but I got the same error message. And it takes too long to register in it. What is going on here? Please help me.
Read moreHi. Please help me solve my problem with CPU-Z.
I was in the middle of my work when this error popped up saying: An error occurred when opening the driver.
CPU-Z will launch but not all information will be available.
After that error some of my data becomes hidden.
I tried restarting my computer and it would work smoothly in few minutes.
But after that, the same error message popped up again.
And I need to restart my computer again to make it work.
Please I need some help.
Driver Error
An error occured when opening the driver. CPU-Z will launch...
Read moreI still have a lot of space on my hard drive. I checked on it so I am certain about it. After having my hard drive defragmented by using Auslogics Disk Defrag, specifically the option called Defrag and Optimize, an error in the system is telling me that there is no more space on my hard drive. I tried using Windows Explorer and it tells me the same. The error says that: "There was zero space on the drive and data could no longer be written." This means, files could not be saved or created on my default drive....
Read moreI’m having problems with Avira AntiVirus Personal. After using it for few months already, it just suddenly malfunctioned. The error occurred I think after setting up the automatic scheduled scan. I set a weekly scan for my computer. It worked well at first. Then it just stopped. The window disappeared before it finished scanning.
Then an error message popped up saying: "avscan.exe – Application Error. The instruction at 0x011ddf27 referenced memory at 0x00000000. The memory could not be read." I already have tried manual scan but it still did not work.
Read moreAd-Aware was shut down unexpectedly and has generated an error report.
Hello, I got that message above after I installed Ad-Aware Version 8.2.
I scanned my computer using my newly installed Ad-Ware.
It suddenly stopped scanning after few seconds and at the same time showed me this error message.
It constantly showed up after having tried to scan again for quite few times already.
Anybody knows how to resolve this problem?
Read moreGreetings! I got an error with Microsoft Office 2010. A few months after I had successfully installed it on my computer, I was able to use it without problems. But recently, I could not be able to open Microsoft Office applications such as MS Word, MS Excel and MS PowerPoint. An error message popped up saying: “The application has failed because its side by side configuration is incorrect please see the application event log for more detail.” I have tried to revert to Microsoft Office 2007 and it worked well. What could be the problem here? Please help me....
Read moreHello!
Please help me solve my problem regarding FrostWire. I am using Windows XP Professional SP3. I have updated my JAVA to the latest version. I wanted to use a second account of FrostWire with it but I was unable to. When downloading in FrostWire, the downloading progress will instantly start but will suddenly stops.
An error message came out and was just giving me three options which are either to retry, to abort or to cancel the download. I tried the three but nothing worked. But it actually works fine with the first user account. Please help me fix this...
Read moreHi,
I need to know what to do with my Comodo antivirus error. I have been using Windows 7 in my computer. Every time it asks me to install its updates, I just do. Now I have installed its updates on security, Windows Malicious Software Removal, and Windows Defender.
After having installed all those mentioned updates, I could not use my Comodo Internet Security at all. I could not make it start. I used to install these kinds of updates every time there are available updates but I just had this error for the first time. Please give me helpful comments.
Read moreHello! I always get this error message every time I open ObjectDock. My operating system is Windows XP Professional 64-Bit. I am having this error stating: “The procedure entry point_except_handler4_common could not be located in the dynamic library msvcrt.dll.” This .dll key is located in the ObjectDock program directory and both in Windows System 32 and SYSWOW64. I have just installed the latest ObjectDock and I wonder why it is faulty. I always update to the latest version. But it would just work out fine after clicking the OK button. And I can work normally with it. My only...
Read more
