Archive
I am using Zune software and I was unable to update it. I have tried to uninstall the old version and install the newer software. But the error is still the same. The error code I am getting is 0x80004005.
I have tried to find the solution for it but failed. Tried to re-install it and the installation starts from 15% and then jumped to 91% and then give this error message. I am sure that I have downloaded the proper version from internet. I am using window 7 32-Bit. Need help.
Read more
I have several songs that are unable to play in my iTunes. Sometimes it will play for about 1 minute and 30 seconds but most of the time, it don’t. But through the point on it can be played easily. Is there any method to play this song correctly in iTunes?
Read more
When I start the latest version of iTunes on my computer which runs Windows XP, this error message appears.
If I click 'Cancel', the computer remains OK though when I start to run other programs, the same error message reappears.
No any other CD-burning software is using.
I try to reinstall the iTunes driver and the error message still continues to reappear.
Please help and thanks in advance.
'Error Message'
‘The registry settings used by the iTunes drivers for importing and burning CDs and DVDs are missing.
This can happen as a result...
Read more
Due to some errors, my Pinnacle Dazzle was unable to record audio. I can record videos but there is no audio recorded. I am worried about this problem. I have tried too much to find the solution but I failed. I will be thankful if anyone helps me and I will appreciate it.
Read more
I got this error message when I tried to install the game Broken Sword on my Acer laptop. I have tried to reinstall it to no avail. The error that is stating: 'error number 0x80040702 description: failed to load dll: mtxckr setup will now terminate'. How can I install the game without having issues?
Read more
Currently I was using a Sony Vaio notebook which was equipped with Intel Core 2 Duo CPU. When I tried to update the iTunes to Version 10.1.1 from Version 10.0.1, this error message appeared.
Please advise what I shall do.
Many thanks.
'Error Message'
The update iTunes can't be saved - a networking error has occurred. Cannot open file (-3001) Make sure you can connect to the internet and try again.
Read more
I tried to backup the data from my Apple iPhone 3G S but I get this error message. I do a normal backup of my mobile phone but this is the first time that I encountered this problem. How can I resolve this?
iTunes could not back up the iPhone "Apple" because the backup could not be saved on the computer.
Read more
I just re-installed Windows XP recently. I have a Desktop Manager in my machine. When I tried to update it, I got this error, “device has not much space”. Now that I already free some space and I have unchecked the application, the issue is still the same. I want to download the new software. How can I restore Desktop Manager? Please help.
Read more
When I tried to take out the battery of my BlackBerry Bold 9000, it gives me this error message and I am unable to go to the further stage. The error is “Reload Software: 552“. Please assist me. Thanks.
Read more
When I installed Roxio Creator 2012, many errors appeared. I tried to reinstall the program several times but same error message appeared repeatedly.
‘Error Message’
Setup has determined that your configuration does not support any of the included products.
Read more
