Archive
How many bytes are stored in float type?please identify the term Floating Point Variables
Read more
I am using Windows XP Pro with 256 MB RAM Pentium 4 2.4GHz . Will it be sufficient to run 4 to 5 computers for data sharing and printer sharing . This is for home use only.
Read more
I am a beginner. I want to know how to connect two computers. What are all the components do I need and which software’s are needed ?
Read more
hi,
I got this error while using a defrag software (see screenshot of the error message below).
I tried uninstalling and installing the software, but I still got the same error.  The error message was cryptic and didn’t suggest any resolution.  I searched the internet but couldn’t find a possible answer.
Can an expert from this forum help me?  Really needed to defrag my hard disk.
Error
Runtime Error (at -1:0)
Cannot Import SCALEX
Read more
Hi Experts,
I added a task to the Task Scheduler the other day for it to be started yesterday.
However, I received this error message when I tried starting it (please see below).  I checked the scheduler, and it was running.
I tried rebooting the PC Server and tried doing the tasks again, but I still got the same error.
I am now calling for experts in this forum who can help solve the problem.
Please help.
I am new to this job.
Task Scheduler
General page initialization failed.
The specific error is:
0x80041315: The Task Scheduler Service is not running.
An error has occurred attempting...
Read more
Yes, I have an old RivaTuner v2.0. I got this error message below when I tried to use it on a new NVIDIA card.
Anyway, my question is; which version should I get?
Where could I get the right version for my card?
Please guide me.
Unsupported driver detected
Warning! RivaTuner has not been tested with the currently installed display driver.
It is strongly recommended to upgrade RivaTuner to a new version. Otherwise it may not work properly because the driver is not officially supported
Don’t show this warning till installing new unsupported driver
Read more
Hi Gurus,
Got this error (see below) when I installed Armed Assault game on my brother’s desktop PC.
It seemed that the graphics card wasn’t working.
How would I know if I need to replace the card or just upgrade the driver?
Can someone help me?  Thanks in advance.
ArmA
Cannot create 3D device:
Adapter 0(NVIDIA GeForce 6800 GS)Fullscreen
Resolution 1024x640, format X8R8G8B8/A8R8G8B8/D24S8, refresh 60 Hz.
Error D3DERR_INVALIDCALL
Read more
I got an Overclocking Utility for my EVGA graphics card so I could tweak it for maximum performance.  But, I got this error message after installing it.  I tried reinstalling but I still got the same error message (see below).
Any solution to the problem?
EVGA Precision
RTTSH.dll::Delete Task failed with error code -2!
Read more
I was copying a file from a Server to a PC when I got this error message below.  Both network connection and the server were active and operational when I checked.  I tried copying again after rebooting both PC and Server but I still got the same error.
Any advice on how to resolve the problem?  Need your answer ASAP.  And, thanks in advance.
Location is not available
C:User refers to a location that is unavailable. It could be on a hard drive on this computer, or on a network. Check to make sure...
Read more
I recently received this kind of the error message every time I connect a device to the USB ports (see below).
I am using RocketDock, and it is working fine.
Please help me. I can’t use my USB ports which is driving me crazy.
Rocketdock.exe – No Disk
There is no disk in the drive. Please insert a disk into drive DeviceHarddisk4DR5.
Read more
