Archive
I was using a 9861 NI-XNET module in a CompactDAQ form factor configured for FPGA mode with a DMA FIFO. However, when the FPGA VI was compiled, an error message (see screenshot below) popped up during the generation of intermediate files.
Any advice on how to get rid of the problem?
Code Generation Error Items with Errors FPGA.vi Errors The current target does not have sufficient DMA control line sets available Resource: ’FIFO’(read Interface)
Items with Errors
FPGA.vi
Errors
Details
Too many sets of DMA controls lines...
Read more
I was using the LabVIEW FPGA Module and LabVIEW to create VIs on FPGA targets. However, while changing and saving items under the FPGA target in the project, I got this error message (see screenshot below). I wondered why this happened because I have already tested the same changed item before and it worked.
Anyone from this forum who could help me resolve the error?
Error -61017 occurred at Open FPGA VI Reference in UDV RT.vi
Possible reason(s):
LabVIEW FPGA: You must recompile the VI for the selected target.
Read more
I was installing LabVIEW 8.6 to a new PC with Win 7 but it failed sending a build error message (see screenshot below).
I tried it for several times but the error seemed to happen again and again.
Can you please help solve the error?
Thanks in advance.
Build Errors
The build was unsuccessful.
Possible reasons
An error has occurred. Expand the Details section for more information.
Details
******Error: Windows SDK function returned an error. (Error code -12)
The system cannot find the path specified.
******Error Details:
Error in MDF API function:_MDFDistCopyList_CopyItem
Windows function FindFirstFile returned an error. Error code:3
***End Error Report
Read more
I was configuring NI PXI-4110 with LabVIEW when I got this error message below.
I am a fairly new to this field, and I couldn’t figure out how to resolve the issue.
I searched the internet but couldn’t find any resolution for my exact problem.
Can you help?
Error -1074134971 occurred at Property Node
(arg 2) in Untitled 3
Possible reason(s):
The channel or repeated capability name is not allowed.
Attribute: NIDCPOWER_ATTR_MEASURE_WHEN, Channel:0
Read more
I was debugging XDS100v1 emulator with Code Composer Studio v3.3.  I tried a new target configuration but I got this error message (see below).  I have verified the target configuration and seemed okay.  I have reset the emulator and I still got the same error.  I searched the internet for answers but couldn’t find one.  I hope anyone from this forum could help me solve the problem.  I may have missed something. Thanks.
Texas Instruments XDS100v1 USB Emulator_0/C28xx
Error connecting to the Target:
(Error -1135 @0x0)
The emulator reported an error. Confirm emulator configuration and...
Read more
I was happy using my HP Photosmart M22 Digital Camera until yesterday when this message appeared on the LCD (see below).  I tried turning it off then on but nothing happened to improve the status of my camera.
I am not a techie person so please teach and guide me  how to reset the camera.
Thanks in advance.
Camera has experienced and error.
000000C8-8BE7-586-053
Please reset your camera or consult your User’s Manual.
Read more
Hi Experts,
I was trying to power on a VM via Vcenter when I encountered this error message below (months ago).
So I restarted the host then it was fine.
However, I started getting the error again which seemed intermittent.
Got any solution to get rid of the error message permanently?
I depend on you guys. Please help.
Thanks in advance.
Power On virtual machine
The operation is not allowed in the current connection state of the host.
Time:                        2011/10/9 10:42:23
Target:                     vc5win_wuchuang_110
vCenter Server:         VCENTER5-100
Read more
I got this warning message when I accidentally pressed the power button of my PC.
Improper shutdown
You pressed the power button.
This probably won’t hurt anything.
Then again, you’re running Windows, so who knows?
Will this damage my PC?  It was a funny message though.
Anyway, how am I assured that nothing happened bad to my PC.
Please help.  I am bit nervous.
Read more
I bumped into this error message while recording a composition using Pro Tools 9 on my Mac.
The operating system held off interrupts for too long. If this occurs frequently, try increasing the “H/W Buffer Size” in the Playback Engine panel. (-6086)
First time I came across with the above error that I had to search the internet for answers.  Unfortunately, I did not get any solution.  So, I chanced upon this forum and would like to ask help from you expertise.
Can you give advice on how to resolve the problem?
Read more
I was a newbie Pro Tools 9 user on a Mac. Actually, it was my first time to tinker on an audio software.
Anyway, I got this error message (see below) while using it, and I didn’t know what to do.
Can someone from the forum give a step by step guide on how to resolve the issue?
Hope he is patient enough to help me.  Thanks.
You are running out of CPU power. Remove some RTAS plug-ins or increase the CPU Usage Limit in the Playback Engine dialog.
(-9128)
Read more
