Archive
I am very confused in Integer Arithmetic and the terms in it,please help me in Negation,overflow Rule and Subtraction Rule.
Thanks
Read moreI am getting (in a pop-up window) error when my FPGA code has finished “Compilation” successfully. This message keeps on appearing even after rebooting my PC and the LabVIEW Real-Time Software. I removed the program and re-installed it again but still encountering problem. The error is: “An internal software error in the LabVIEW FPGA Module has occurred. Please contact National Instruments technical support at ni.com/support.”
Additional Information:
Original error message:
Error 6 occurred at Write to Text File in niFpgaWriteBitfileXml.vi >niFpgaCompileDownloadRun.lvlib:cdrCreateBitfileForCompilation.vi >niFpgaCompileDownloadRun.lvlib:nirviCompileDownload.vi->hardware_template.vi Possible reason(s):
LabVIEW: Generic file I/O error.
NI-488: I/O operation aborted. \.hostShared FoldersDocumentsLabVIEW DataDRELS ProjectFPGA BitfilesDRELS Project.lvproj_FPGA Target_6RadiosTest.vi.lvbitx
Please help me with this...
Read moreRecently I purchased a Labtec Web Camera 2200 and was very eager to use it. When I tried to install the software for the webcam, I am getting this error “The software you are installing has not passed Windows Logo testing to verify accessibility”. I am not an expert when it comes to computers, so can somebody help me? I do not know what to do.
Read moreI use Paint Shop Pro (PSP) to edit my RAW photo files to make adjustments and things you do with photos. Anyway, I was using the Image Browser when I got this error message below. It was a cryptic message and no suggested resolution was even indicated. I didn’t know what to do next when the PSP stopped working after this cryptic message popped up.
Paint Shop Pro X
An invalid argument was encountered.
I restarted PSP and well, intermittently the cryptic message showed up again.
Anyone knows how to get rid...
Read moreEvery time I run the program Camera Assistant, an error message displays that says, “CEC_MAIN.exe couldn’t execute”. I believe I should re-install the software. However, I really cannot find a solution to this issue. Can somebody help and assist me on this problem so I can use the Camera Assistant again? Thank you!
Read moreI have a Windows XP computer system and recently, I opted to uninstall Kodak Easy Share and Kodak updater program using add/remove program feature in Control Panel. However every time my computer starts up this message pops up, “Runner Filename (Kodak Software updater.exe) lacks a (the app id separator)”. I really do not have an idea to resolve this issue.
Read moreI couldn’t make Gamer HUD work with a newly bought Gigabyte nVidia GeForce 9800GT and I was getting this error message (see screenshot below).
I tried reinstalling the driver but I still couldn’t make it work.
Do you have a solution for this? Please help.
Gamer HUD
Not support this VGA Card!
Read moreIn system support there are three main scheduling that are Long Term,Short term and Medium term scheduling.
Differentiate these terms.
What are the main difference.
Read moreHi Experts,
I was trying to program the AVR flash with AVRISP MKII and AVR Studio when I got this error message below. I am a newbie in this field and I didn’t what’s wrong.
Please help me out here, guys. I need your expertise.
Thanks in advance.
AVRStudio
There seems to be a short circuit on the ISP connector.
The RESET line(s) appear to be short-circuited.
The operation will be aborted.
Read morehow operating system control the execution of applications and programs and what ll be operating system objective?
Thank you,
Read more
