Archive
I have reformatted my Windows XP. Now, every time I am installing an application I am getting an error message that says, ‘the system is not modified’. If anybody knows this issue, please help me. Thanks in advance.
Read moreI am looking for help to fix an Internal Error 2755.3. This started when trying to install the Sperry application add-in, an error message is coming which says ‘Internal Error 2755.3’ and an error ‘pathname/mapped drive not found’. Please help me to solve this issue. Thanks in advance.
Read moreI keep getting an error message when I tried to install Nero Ag Register Com Ex for LG DVD player.
So, it is not loading correctly.
The error message is, DLL file is corrupted in the last function.
The installation will quit. Please help me to figure out this problem.
Read moreI have accidentally deleted a very important task under the Task Manager. Now, whenever I start the system it gives an error message, ‘The HP software update failed because it is missing the software library. The software is to be re-installed’ , and then the software will close. Please help me to get out of this problem. Thanks in advance.
Read moreWhen attempting to start AutoCAD, an error message says ‘Fatal error : Exception at 7c81eb33h. AutoCAD is aborting because the software is generating an exception which cannot be able to handle’. Please help me to get out of this problem. I will be thankful for all the help and support.
Read moreI am getting an error message which says that ‘Content download for the application and the program for advertisement has failed’. I have verified that the application has the capacity to download locally to the system. I have also set up the application to run with user rights and the all users is having administration power in the computer. Please help me to solve this problem. Thanks in advance.
Read moreMy Operating System is Windows XP 64-Bit. I am not able to mount any image with ‘ImDisk’ as every time I tried, it gives me an error message stating that, ‘ImDisk Virtual Disk Driver loading error. It is not able to load as it has been blocked’. Please guide me to fix the issue. I will be thankful for all the help.
Read moreWhen I tried to install any software on my computer, an error message appears that says, Runtime Error 53. It is not able to find the file ‘olepro32.dll’. So, I cannot install any applications because of this issue. Please give me a solution for this. Thanks in advance.
Read moreI have installed ‘Avast Anti Virus Home Edition’. When I scan the computer with this Anti Virus Software, it removed the file ‘kesenjangansosial.exe’ from windows folder. It was removed because that file was detected as a virus by the Avast. So, when I am booting my computer it gives me file is missing error message. Please help me to get back those file. Thanks in advance.
Read moreI am getting an error with SQL Writer prompt box stating, “SQLDUMPLER library failed initialization.
Your Installation is either corrupt or has been tempered with.
Please uninstall then re-run setup to correct this problem.
This error is appearing every time I boot up and clicking the OK button will make my computer continue working, but I think it is now interfering with some of my programs that are actively running.
What is this error and how should I fix it?
Read more
