Archive
Hello. Few days ago, I was trying to install Lives new package through internet in my PC. During the installation, I received an error message saying: “Error: Dependency is not satisfiable: libmjpegtools0c2a.
I tried to solve this issue by downloading the package from some other online site, but I received the same error message.
I have asked my friends for help but they don’t know the solution for this so I am posting my question here in any case that someone can answer it.
Kindly please help me.
Thank you.
Package: lives
Error Dependency is not satisfiable:
Status: libmjpegtooIs0c2a
Description Details Included Files
Linux...
Read moreGood evening to all the IT Masters here,
I need your kind assistance with the MPCVideoDecoder.exe. I received an error message from RegSvr32 stating that:
"RegSvr32
The module “C:Program FilesMPCVideoDecoderMPCVideoDec.ax" was loaded but the call to DllRegisterServer failed with error code 0x80070005.
For more information about this problem, search online using the error code as a search term."
Now, I was having a bad feeling about it and thinking if I would get this problem solved or not because I need to use this Video Decoder very often. So please...
Read moreI need some help about an error message. Today, when I was performing HWK Update Clients on my PC, I received an error dialog box saying that:
“HWKUpdate Upgrade Client
Error connecting UFS! -15 Please Reinstall Support Suite !”
So in this case, I had entered the correct login and other details but I don’t know what is causing this error to appear.
I am new to this sort of problem so I don’t have any idea on how to rectify it. If someone knows the answer or if you know what to do with it then please reply to my question.
Hi Experts. I need you help regarding software here. I was installing Digital Movie Creator Version 3.0. This software can be used to edit and create your own movie. During the installation, I didn’t get any error or problem.
However, after completing the installation process and run the software, I clicked on to start recording the movie from my camera connected to my PC.
There is nothing wrong with my camera as it is connected and working but when I try to use the camera with this software, the error started to appear.
So if anyone out there who knows how to...
Read moreI am stuck with an error which I cannot resolve. I hope someone can help me with it. I was trying to install Red Hat Enterprise Linux Server since I am using VMware software. All directories and drives were fully formatted before the installation but as soon as the installation started, a blue screen along with a dialog box appeared saying that:
The Red Hat Enterprise Linux Server installation tree in that directory does not seem to match your boot media.
Now I am not so sure if this error is because of any invalid directory or due to the installation...
Read moreDear friends, I want to discuss an error problem with you. I am running AutoCare application on my Windows XP 2002 Service Pack 3. When trying to run the .exe file, the error dialog box from AutoCare.exe appears saying: “An error occurred in the application.” There are some options in the dialog box which you can see on the image below.
I have tried all these options one by one, but none of them had helped to resolve the issue.So I am requesting you to please take a look at the image below and if you know how to resolve...
Read moreHi..
Please help in this topic.
An error occurred during directory enumeration. I will be very thankful if you solve my problem.
Thanks
Read moreGood day everybody. I am here today with an issue regarding AutoCAD. This error appeared when I tried to run AutoCAD yesterday on my PC. A few days ago it was working very fine, but just yesterday it appeared saying: “LICENSE ERROR -
Your license is invalid. Please contact your local authorized AutoCAD dealer.” And another error box appears in which it shows:
“AutoCAD Error Aborting – FATAL ERROR: Unhandled Access Violation Reading 0x0010 Exception at 62715f41h.”
Now can you please help me with it as I don’t know how to rectify this problem. Why does it say License error?
Has my AutoCAD...
Read moreHi
Would you please like to tell me that how i can clear the cache of my Internet Explorer 9?
Read more
Hello friends. I am having some problem during the launching of 3ds Max on my PC. I have Windows 7 installed on it.
Other software’s are working fine but when I try to launch the 3ds Max Design 2012, an error appears with the given image saying that “3dsmax.exe - Entry point Not Found. The procedure entry point…
Could not be located in the dynamic link library splash.dll.” I need your assistance to solve this issue. Please help me and tell me why does this error appear and the reason why the software doesn’t run. If anyone knows the right solution...
Read more
