Archive
The 1TB Iomega networked media drive is not identify. I want to get back again all my files on HD before I am going to turn my car above the new paper value. Please share your ideas. Thank you.
Read more
Please help me on my CMOS display errors. I am having this error, CMOS checksum error – Defaults loaded Press F1 to continue or Del to enter setup Pressing F1 will continue opening my Windows XP desktop. Pressing Del will allow me to enter my BIOS settings. I am receiving a series of hangs and freezes and I cannot set the clock correctly. If I set the clock, it will automatically go back to previous year 2006. And will give me error on expired certificate. I want to know how to reset my CMOS battery, as this...
I am upgrading my Lion but I could not find the Iomega external hard drive then need to set up Lion and back it up and plug in the lomega hard drive but the notification appears that the "Time Machine did not accomplish the back-up" and "the back-up disc is nonexistent" any objective? Is there someone could make it?
Read moreHi Techyvs,
I'm looking for a graphics card for my laptop. I'm gong to use it mostly for gaming, but I don't know what kind I'll need.
My laptop is a HP G60 Notebook PC, The processor is an AMD Turin Dual-Core RM-75.
I believe the laptop is several years old, but still runs fine.
I'm not looking for a specific card, though if you know one that fits perfectly, feel free to share.
I'm looking for some info on what I should look for in a card. If you need any more info on the laptop, ask and I'll edit.
Thanks
Read moreHi There!
DVD disk burning problem. Please help me. My DVD writer is a Samsung product. It reliable and good CD/DVD writer all over the world. So normally I use it. But sometimes I cannot write any DVD or CD disk. It has a writing problem already that's why it cannot burn anymore.
Read moreHi There
I have a general problem. It is keyboard problem for me. I cannot write anything.
Thanks,
Read moreI am recording a video of skateboarding using a Digital Versatile Disk-Recordable (DVD-R), however, for some explanation can be refined on the computer. The disk is not acceptable instead I should use DVD-RW for camcorder or Digital Versatile Disc Rewriteable (DVD-RW) disc to the computer? What is the difference between the two and why I can’t use DVD-R?
Read moreHi, considering that you want me to use this set up, I guess you fix the situations already. But I want to post this message at the forum rather than sending you a private message because I want to share it to the public considering that there are someone encountered also this kind of troubles and could give me tips to resolve it.
The bad situations is, totally it is working very well but only for this one portion. The PB is always blocking (Multiple Direct3D loaded) problems. I have seen this problem similar to mine in the forum. Still...
Read moreHi,
When I save a document using an application program, such as MS Word, MS Excel, the file is automatically saved in My Documents folder, unless I choose a different location.
My documents is also a special folder on the desktop.
It is the standard folder of windows XP and is automatically installed. I want to change my doc file,
Default location.
Please help.
Read moreHello, lately I brought a modernized motherboard, CPU and RAM. Because of the cd-room that had bad situations, I am not able to set up the audio / video drive and others that is in the cd room which comes from the motherboard. I decided to download all of them and set up in the company website. The bad situation is when installing the ZD soft screen recorder, it runs only a seconds then and stop the installations and crashed. A notification says ZD soft screen recorder is facing a bad situation and closed the message, the video also...
Read more
